Amp lead
krayzie2k3
Copper - Posts: 47
Posted: June 20, 2005 at 11:07 PM / IP Logged
what is the voltage going through the amp turn on wire coming out of the headunit to the amp?
stevdart
Platinum - Posts: 5,816
Posted: June 21, 2005 at 1:08 AM / IP Logged
~12 volts from aftermarket head units.  Some factory decks provide a 5 volt signal to the proprietary amp.  Amperage?  Less than 1/2 amp.
Teamrf
Gold - Posts: 1,031
Posted: June 21, 2005 at 1:11 AM / IP Logged
Dang I was too late.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
krayzie2k3
Copper - Posts: 47
Posted: June 21, 2005 at 12:28 PM / IP Logged
on a stock head unit running to an amp to power a sub, would i be able to run the remote wire off of the ign 12V wire? would i need an inline fuse or anything like that? thanks
mthomecouple
Member - Posts: 24
Posted: June 21, 2005 at 12:53 PM / IP Logged
i have ran from the ign. wire before with no in line fuse and it was fine for me.
joe
outlaw000
Member - Posts: 42
Posted: June 21, 2005 at 1:38 PM / IP Logged
run it from the ignition,s accesory wire not 12v wire or else it will drain your battery
stevdart
Posted: June 22, 2005 at 7:25 AM / IP Logged
Yes, fuse the remote wire.  Just for the sake of safety when connecting to any power source.  You can get a 49 cent fuse holder and a 5-pack of 500 mA (1/2 amp) fuses locally or through PartsExpress...fuse location is near the source, as usual.  I have a 500 mA fuse in the remote lead from a switched 12 volt wire, splits to two amps, and have not blown a fuse since the install a year and a half ago.
kgerry
Platinum - Posts: 3,455
Posted: June 23, 2005 at 9:59 AM / IP Logged
until the wire shorts somewhere in the car and starts a fire or burns up a bunch of wiring..... fuse it !!!
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
