99 Honda Civic 2dr EX alarm
sparkie
Platinum - Posts: 2,061
Posted: January 15, 2004 at 7:58 PM / IP Logged
The dorr trigger wire is light GREEN/ red (-). It can be found in the driver's kick panel or in a light green plug either behind or to the left of the radio. This plug is for the factory alarm.
sparky
krayzie2k3
Copper - Posts: 47
Posted: January 15, 2004 at 8:08 PM / IP Logged
is that for the left door or right door control to make it lock/unlock? thanks
auex
Platinum - Posts: 5,041
Posted: January 15, 2004 at 8:12 PM / IP Logged
The door triggers are not the lock wires. Here is a link to a diagram of your car.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
turbodcivic99
Posted: January 15, 2004 at 11:06 PM / IP Logged
sorry for sounding so novice, but  what is a door trigger? i understand that with door unlock/lock is where you attach the wires from the alarm harness. what does the door trigger do? thanks
Moderator - Posts: 12,488
Posted: January 15, 2004 at 11:14 PM / IP Logged
The door trigger wire(s) tell the alarm that a door is open so that it will activate the alarm when it is armed.
turbodcivic99
Posted: January 15, 2004 at 11:44 PM / IP Logged
ok, i understand that aspext.
this is the diagram from the box http://www.geocities.com/sl_600_v12/clifford1.jpg and http://www.geocities.com/sl_600_v12/clifford1.jpg and im trying to make it work with my 99 ex https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Honda&model=Civic&ID=17975&type=Alarm
this is what i came up with so far:
                            harness     | honda
ign                      yellow         | BLACK/ white
instant trigger   blue            | blue/black
accessory         RED / white    | WHITE/ black
12v constant    red               | battery
horn                  brown          | siren under hood
domelight        dont care
starter              black            | BLACK/ white
light flash        dont understand
door(guess)   blue              | GREEN / WHITE
Posted: January 16, 2004 at 9:28 AM / IP Logged
Not sure about that instant trigger wire ( maybe for the hood, trunk or any other (-) triggered spot on the car ). The only problem with the above list of colors is that ytour IGN wire is suppose to be BLACK / YELLOW at the ignition harness and your door trigger is supposed to be LIGHT GREEN/ RED at the OEM alarm plug to the right side of the steering column.
The light flash wire on the harness is suppose to go to the RED / BLACK wire at the keyless entry module ( white in color, and located in the drivers kick panel ). THis will flash the lights when locked and unlocked or keep them on when remote started.
turbodcivic99
Posted: January 16, 2004 at 10:22 AM / IP Logged
is that for the light flash input or output?
99 Honda Civic 2dr EX alarm - Page 2 -- posted image.
turbodcivic99
Posted: January 16, 2004 at 10:41 AM / IP Logged
and for the door trigger, i connect the Green wire from the alarm to the Litght GREEN/ Red wire to the honda harness?  and for the door lock/unlock i connect the GREEN / WHITE(-) to the Blue for the unlock and GREEN/ Orange(-)  to the Green for unlock? thanks. i dont have to use diodes becuase the civic is internally relayed, correct me if im wrong.
Posted: January 16, 2004 at 11:07 AM / IP Logged
The WHITE is suppose to go to the RED / BLACK at the at the keyless entry module. Yes, attach the GREEN from the alarm harness to the GREEN/ RED on the Honda. The door lock description you had is correct.
Page of 4
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
