2001 Honda Accord, amp w/factory HU
krayzie2k3
Copper - Posts: 47
Posted: June 13, 2005 at 2:16 PM / IP Logged
parts: 4ch amp, JL 6.5 inch in the front and JL 6x9 in the rear, using stock headunit.
objective: run all speakers from the amp to utilize a cleaner and crisper sound.
ive read up on a few other posts but cant find the exact info im trying to locate.  i ran all the wires from the speakers into the amp. ran the 4guage amp wire from the battery to the rear. ran the remote lead to the rear. and grounded it on the frame.  my thoughts are to get the analog to RCA converter for the front + rear channels and run RCA wires to the amp.  am i approaching this the correct way? thanks
us_test
Copper - Posts: 200
Posted: June 13, 2005 at 4:13 PM / IP Logged
Here it is
2001 Honda Accord, amp w/factory HU - Last Post -- posted image.
Teamrf
Gold - Posts: 1,031
Posted: June 13, 2005 at 5:14 PM / IP Logged
Yes.. You will need to use two line out converters for a four channel amp. Then you should be in business. By the way...nice car!2001 Honda Accord, amp w/factory HU - Last Post -- posted image.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
krayzie2k3
Copper - Posts: 47
Posted: June 13, 2005 at 11:12 PM / IP Logged
i havent chosen an amp yet. another question is after i run the RCA wires to the amp, is the 4 ch amp supposed to have 2 inputs [front and rear] ?
us_test
Copper - Posts: 200
Posted: June 15, 2005 at 7:18 AM / IP Logged
4 channel amp has 2 sets of RCAs (4 cables).  I suggest some of the following amps, autotek, hifonics (these are the ones I like but there are others).
accord78
Copper - Posts: 97
Posted: June 15, 2005 at 5:48 PM / IP Logged
i have a 98 4 door accord and here's my setup pioneer DEH-P7700MP head unit. kicker 6 1/2 components in front tweeters are placed where factory tweeters are in the dash and kicker 6x9 3 way in the back deck. and 2 10 inch polks in the trunk all runing on MTX 5 channel amp plenty of power. sounds freaking loud as hell and clear. if i was u go with an after market head unit why do all that work just to use the factory head unit????? kinda point less.. it's just like adding nice speaker runing of the head unit lol
jlpio
Posted: June 17, 2005 at 2:07 PM / IP Logged
Scosche has a nice four channel line out converter (model SLC-4) that has worked nicely for me in the past. However, many amps are available with speaker level inputs, which may give you better results (or at least a cleaner looking install) than using a LOC.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
