clifford dual zone prox set up?
steveo29
Member - Posts: 36
Posted: January 01, 2006 at 3:38 PM / IP Logged
ok i have g4 clifford, i currently have the prox sensor behind the shift lever and its not very good there
ive been told the roof would be a better option, but i can only really fit it  just behind the windscreen, kinda between the visors .  is it going to be too far forward??
Powermyster
Silver - Posts: 962
Posted: January 01, 2006 at 4:29 PM / IP Logged
probably would be.. try it and see if you can adjust it to suit your needs. post your findings
Why oh Why didn't i take the blue pill
Darren Power
ringojam
Copper - Posts: 215
Posted: January 01, 2006 at 6:29 PM / IP Logged
Put in the head liner near the dome light for best proformance,extend the wires if needed.Remember if there is tint that is of the metalised type it will reduce the proformance of the sensorclifford dual zone prox set up? -- posted image.
Jamaica home of the worlds fastest man.
steveo29
Member - Posts: 36
Posted: January 02, 2006 at 4:27 AM / IP Logged
ringojam  the area that you describe has the inner metalwork for the sunroof , i dont think i will be able to hide it without the liner buldging
steveo29
Member - Posts: 36
Posted: January 02, 2006 at 10:46 AM / IP Logged
ok a couple more questions, i need to extend the wiring and i have some 8amp wire...will that be suitalble?
i was looking around and i think it could be mounted under the dash, maybe to the heater box or something..will there be any issues fixing it to non metal surfaces?
ryguy
Member - Posts: 44
Posted: January 02, 2006 at 11:03 AM / IP Logged
i have found that fluresent lights ,like work lights  or shop lights have also made the performance poor  on these sensors .  u may want to set it outside or the shop .
MECP installer,technician
sparkie
Platinum - Posts: 2,061
Posted: January 02, 2006 at 3:46 PM / IP Logged
The best place to mount the sensor is on the floor of the vehicle. The sensor does require a 6" x 6" area of metal behind it for best results. I do not recommend that you mount the sensor overhead. The roof of any vehicle does move ever so slightly with wind and other environmental factors. If the roof does flex or move even imperticeptably it is enough to cause the sensor to false. It does this because it will see the entire sensor field area that it monitors move in and out away from the sensor. Even mounting the sensor to a roof brace isn't good enough.   Mount the sensor under a seat close to the center of the vehicle. As mentioned, window tint will prevent the sensor from seing beyond the windows. The sensor will penetrate most things except metal. All window tint has atleast some metal content. The darker the tint the less the sensor will see through. Be patient and take your time setting it up to get the best results.
sparky
ringojam
Copper - Posts: 215
Posted: January 04, 2006 at 8:10 PM / IP Logged
I hav found puttin it center console is good for some applications, waggons it dose not work too good or on some hatch back cars thats why i like the roof,never had a problem in a roof applacition it etremely hot down here  never had  problem your advice is well taken sparkieclifford dual zone prox set up? -- posted image.
steveo29
Member - Posts: 36
Posted: January 10, 2006 at 7:35 AM / IP Logged
okay ive decided to move my G4 c 600's dual zone proxy sensor to the roof, ive gutted half the car and ready to move it
i cut the wire expecting there to be just a BLACK/ BROWN / red..but theres a bare braid running along inside and then the whole lot is wraped in foil the the normal outer covering
what do i do to extend it??
cosmoworks
Copper - Posts: 144
Posted: January 10, 2006 at 11:02 AM / IP Logged
You'll have to use 3 conductor shielded cable to extend it. The outer wire is a ground shield. You can try to just extend it with standard wire, but could potentially get noise and false alarms.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
