2001 monte carlo door locks
dantheman89
Member - Posts: 9
Posted: September 22, 2008 at 7:56 PM / IP Logged
I have a 2001 Monte Carlo and I have tried everything to get this single wire system figured out i can get each wire to work by its self but cannot get them to work together.  I have already got the 470 OHM resistor.  I just need a very detailed explaination on how to hook it up. Oh btw hooking up a Viper 5900sst I have a 451m relay will this work? If so tell me how please.
Thanks,
Daniel
caraudio904
Copper - Posts: 115
Posted: October 22, 2008 at 12:26 PM / IP Logged
ORANGE / blk stripe
lock is with resistor unlock is straight (-) wire
follow this setup you will be fine (same as impala's as well) so print it if need be
2001 monte carlo door locks - Last Post -- posted image.
Southern Stylez
Jacksonville, FL 32218
dantheman89
Member - Posts: 9
Posted: November 29, 2008 at 8:52 AM / IP Logged
Thank you
