a used fiberglass box
sergior
Posted: June 01, 2010 at 12:16 AM / IP Logged
So i purchased a fiberglass box. it looks good and everything. i took it to a shop to get it installed. it did not sound good at all. i tried everything to get it to sound good. messed with the amp and nothing. so i pull the box out and realize that they drilled a hole to run a wire through. so there is a hole with a wire running through it now. you could actually push in the wire from the outside. i was positive this was the reason it wasnt sounding good but i used some jb weld to seal it up and it still sounds the same. can someone please help me out? maybe i did something wrong?
Just trying to get by...
sergior
Posted: June 01, 2010 at 12:17 AM / IP Logged
i have an 05 tsx by the way
bellsracer
Silver - Posts: 703
Posted: June 02, 2010 at 2:31 AM / IP Logged
Did you use the same subs that the box was designed for? That's the first thing I would check. Second, check for stability. Is it rigid enough that the subs are not vibrating it?
sergior
Posted: June 02, 2010 at 11:58 AM / IP Logged
yeah it turns out that the box is too weak. supposedly the guy that had it before had a w6 and had it sounding good. i put a w3 in it and doesnt sound good at all. the box is so weak that you can bend it on some parts of the box. now i am on the lookout for a better quality fiberglass box similar to the one that i have
icearrow6
Copper - Posts: 497
Posted: June 02, 2010 at 12:16 PM / IP Logged
well . . . he WAS selling it for a reason!
sergior
Posted: June 02, 2010 at 12:21 PM / IP Logged
yeah your right. anyone know where i can get a good quality one that will fit in the trunk of a tsx
ianarian
Copper - Posts: 516
Posted: June 02, 2010 at 7:04 PM / IP Logged
Adding more fiberglass support is out of the question?
This is what I do for FUN!
nismo542
Copper - Posts: 62
Posted: June 06, 2010 at 1:23 AM / IP Logged
beef up the inside with some more fiberglass or atleast smear on some bondo with fiberglass in it.  if it is juast weak that is fixable.
