2004 Chevrolet Colorado, Which Bypass? (Pictorial Replies)
specs
Copper - Posts: 120
Posted: November 23, 2012 at 6:06 PM / IP Logged
Hello all....need a bit of advice on which bypass to choose for 2004 Chevrolet Colorado and Autostart AS2371TW, xpresskit preferred as I've used a few of theirs in past installs and familiar with installing software on these. I was going to use PLJX, but just realized it doesn't handle locks.....DB-ALL a good choice? Any advice/tips appreciated.....thks, Al
ziggyb222
Silver - Posts: 593
Posted: November 23, 2012 at 6:11 PM / IP Logged
The PLJX works great on these trucks. The locks are easy to do...
voltswagon
Copper - Posts: 75
Posted: November 24, 2012 at 12:26 AM / IP Logged
I have 2005 and just completed installation.  The PLJX is what i used and it's set default for our colorado.  Also cheap about $20-$25. Lock and Unlock door is with your starter.
Here is a pic, it might help.
2004 Chevrolet Colorado, Which Bypass? (Pictorial Replies) - Last Post -- posted image.
You can use this or direct from Battery as I did using the same hole by the hood cable.
Use this exactly as pictured, specially the jumper.
The brown wire is connect to RS ignition control output when done.
Hope this help.
Dont Drive and Text, but
Do Text Then Drive
specs
Copper - Posts: 120
Posted: November 24, 2012 at 10:29 AM / IP Logged
Thank you both for the recommendation on the PLJX.....voltswagon, appreciate the time and effort in posting the pictures to follow! One question.....the wire colors at your ignition harness picture don't seem to match what the Directed install instructions show..WHITE/ various color stripes versus 3 solid color (orange, blue, brown) wires in the PLJX install instructions?? I'm assuming (as per your photo) the two wires in the ignition harness I will be wiring the PLJX into are the WHITE/ blue and the white green..thks, Al
voltswagon
Copper - Posts: 75
Posted: November 24, 2012 at 11:08 AM / IP Logged
Correct.  That's why it's labeled.  Color code from directed is used for MOST of GM, not all.
Do Text Then Drive
voltswagon
Copper - Posts: 75
Posted: November 24, 2012 at 11:16 AM / IP Logged
You will only need 2 wires from the ignition.
1.WHITE/ green(ignition) to RS and PLJX(pink wire)
2.WHITE/ blue(data) splice in half. From ignition to Pink/white(pljx). From PLJX(blue) to the other spliced end.
Do Text Then Drive
specs
Copper - Posts: 120
Posted: November 24, 2012 at 12:40 PM / IP Logged
Gotcha volts!  Thks again for your time....much appreciated, Al
voltswagon
Copper - Posts: 75
Posted: November 26, 2012 at 11:24 PM / IP Logged
Here's the door locks and unlock.
Do Text Then Drive
specs
Copper - Posts: 120
Posted: November 27, 2012 at 8:52 AM / IP Logged
Thks again volts, much appreciated.....will post back and let you know how it went! Thks, Al
voltswagon
Copper - Posts: 75
Posted: January 04, 2013 at 7:59 PM / IP Logged
This should be a pictorial if anyone is interested.
I'm really happy with this Bulldog Deluxe 2 way pager with PLJX module.
If anyone interested here's some pictorials.
remove the cover:
Under the plastic also metal cover which I didn't need to move and mount my starter/module on to, that you might need to remove
Instead of 3 clips(blue), actually 4 not picture on bottom right.
Once you remove the steering wheel cover you'll see this
If you dont want to remove the steering cover, you can still access the wires on the other end of the harness.
lock/unlock
You might have to remove the metal cover to get to it.  I got small arm.
color code for 2004-2007 colorado that i've used.
I got my 12v straight from the battery via the hold cable.
Below: H5, I only used Ground and BRAKE
H1, all except 2nd ign
H2, all except white2/2 light relay, but you could.
H6, for door
H7, online one 7/1 to module
Hookup to PLJX below
Picture of where my truck park and where I start it from.
Do Text Then Drive
Sunday, September 22, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
