2004 hyundai accent gs, remote start wiring
drw7000
Member - Posts: 6
Posted: February 13, 2008 at 11:04 PM / IP Logged
Hi,
I'm Looking for a remote start wiring diagram for a 2004 Hyundai Accent GS (Canadian model). Also, does this require an immobilizer bypass kit? Thanks for your time.
caraudio904
Copper - Posts: 115
Posted: March 01, 2008 at 8:10 PM / IP Logged
The 556UW is the listed bypass for that car, the only one needing a bypass are the canadian models so yea make sure u get it (556UW)
 MODEL YEAR(S)
 ACCENT  2003 -2005
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   See NOTE *4
 PART  COLOR LOCATION
 12 VOLT CONSTANT  RED (+)   IGNITION SWITCH HARNESS
 STARTER WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 GREEN (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 BLUE (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GREEN (-) or RED / BLACK (-)  @ HEADLIGHT SWITCH
 PARKING LIGHTS ( + ) GREEN/ ORANGE (+) and GREEN/ BLACK (+) Use both, See NOTE *3  IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
 POWER LOCK YELLOW (TYPE B)  @ TACM, 12-Pin Plug, See NOTE *1
 POWER UNLOCK BLUE (TYPE B)  @ TACM, 12-Pin Plug, See NOTE *1
 DOOR TRIGGER GREEN (-)  IN DRIVER KICK PANEL or at INSTRUMENT CLUSTER
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLUE/ORANGE (-)  @ STEERING COLUMN HARNESS
 TACH GRAY  @ ECM, UNDER DRIVERS DASH, PIN 8
 WAIT TO START LIGHT N/A
 BRAKE PINK/BLACK (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 the TACM (Time Alarm Control Module) is located to the LEFT of the STEERING COLUMN NOTE *2 the PASSENGER COMPARTMENT RELAY BOX is located behind the TACM Module. NOTE *3 this vehicle has 2 PARRKING LIGHT wires, that will require 2 extra relays part #775, to connect, See DIAGRAM NOTE *4 the CANADIAN Model of this Vehicle, may have a TRANSPONDER ANTI-THEFT System that will require an extra Programmed Ignition Key and a 791 Security Bypass Module for Remote Starting.
Southern Stylez
Jacksonville, FL 32218
