06 ram 2500 viper starter factory alarm
travisp32
Member - Posts: 20
Posted: December 23, 2011 at 10:46 PM / IP Logged
Also, could this be caused by a bad install? Like shorting something out to cause a problem?
masterodisaster
Member - Posts: 46
Posted: December 23, 2011 at 11:07 PM / IP Logged
Doubt it.
masterodisaster
Member - Posts: 46
Posted: December 23, 2011 at 11:29 PM / IP Logged
Taken from the bulletin:
"SYMPTOM/CONDITION:
You may experience a no engine crank and/or a no engine start condition. Also,
the remote keyless entry(RKE)system may not operate. This condition may be due to an
electrostatic discharge(ESD)from the ignition key in to the Wireless Control Module
(WCM),causing the WCM to electronically lockup. This condition may occur more
frequently in dry and/or cold weather conditions where a sufficient electrostatic charge is
more easily produced. This condition is corrected by the replacement of the WCM.
Until the WCM is replaced,the WCM may be reset(unlocked)by either: disconnecting and
then reconnect the battery negative cable at the battery, or by removing the IOD fuse(with
the key out of the ignition switch),waiting 30 seconds, and reinstall the IODfuse."
Sounds like they made a screwy electronic part, and aren't willing to do a recall.
Once again - good luck.
