This is an update to my own previous posting.
This is a summary and my opinion of the bypass solutions:
The various switch installations These methods work, but involve intalling variations of additional relays or toggle switches. These methods enable the watching of DVDs while in motion, howver, in some variations, the video is patched through the backup camera port. A disclaimer appears on the screen and entering navigation data while moving is questionable.
The dripping solder method using the R197 pins covered by silver tape on the bottom side of the display unit:
This method is the absolute best method, it really does open up the use of the unit without restriction or disclaimers on the screen. The dowside is your ability to solder a jumper between two tiny pins that can only be accessed through a factory access hole in the bottom of the unit. The pins are surrounded by wax which will melt when hot. If the wax melts too much, the pins will be covered and you will not be able to solder. I know, I tried it the first time and failed.
Using some other device to jump the 197 pins:
After the first failure at soldering, I got a new radio and tried using a less permanent method, a screw attached to packing tape. I attached it to tape so that it would be held in place in the access hole and would not fall inside the radio. This method worked, but, I scrapped the idea because it was too much trouble and the screw could come loose. I decided to re-visit the solder method, and devise a better way than dripping the molten solder.
The latest new and improved 197 solder method which almost anyone can do:
1. Uncover the access hole by removing the silver tape on the underside of the display unit. You will see R197 printed over two tiny pins.
2. Put some rubbing alcohol on a small piece of paper towel, wrap it around a small screw driver, and clean the 197 pins so excess wax will be removed.
3. Cut a small piece of sanding paper and using the screw driver rub it over the pins so the solder will have a better chance of sticking.
4. Take some thin electrical wire, must be a size smaller than number 18, strip the insulation back 1/16 inch, and prepare the stripped end by adding solder.
5. Use a soldering iron that has a pointed end. I ground mine down on a grinder to make sure it would easily fit into the access hole and still enable me to see.
6. Holding the wire in your left hand, place the soldered end between the two 197 pins, insert the soldering iron and carefully heat the end of the wire like you are soldering it to the pins. Three things will happen. You will solder the wire to the pins, which is fine. Some solder will drip off and short the pins, which is fine. Or, you will fail, nothing will be harmed if you don't melt the wax. Very little solder is needed. If the wire sticks to the pins, fine, clip the wire off and make sure no bare ends touch the case.
I took my time using method six, the unit now allows unrestricted use.
In all cases I grounded the emergency brake wire, don't know if I had to, but, did it anyway.
You may be violating state law by messing with the radio and watching DVDs while driving. Do this at your own risk.
If you don't know how to solder, or fail at jumping the 197 pins, and you screw up your radio, welcome to the club. That is what testing is all about. If you don't want to take the chance, don't touch the radio. Enjoy it in the stock configuration. This is my last post...until somone figures out something better. My other two Avics are now modified, mission accomplished. I can now watch music videos while stuck in CA traffic, rolling along at ten miles per hour.
