2002 Impala keyless/remote start
duley3
Copper - Posts: 73
Posted: October 05, 2005 at 11:57 AM / IP Logged
Little late now. It's done..But thanks anyway
duley3
Copper - Posts: 73
Posted: October 06, 2005 at 7:23 AM / IP Logged
Okay well you people have helped me out alot with this. Now I have a new problem..
 Everything works fine with the unit. But if I lock the door with the remote and wait a while (over night) the doors will not unlock with the remote. But, If I use the keys to unlock the doors then open and close them the remote will then lock and unlock the doors just fine.
Why would this happen? I first thought it would be a connection some where that was not made good. I have ccheck everything as far as connections and being wired right. Could it be something with the factory alarm on it? If so how can I fix the problem?
thanks
Dave
BTW This is on a 2002 Impala
Evolution-UK
Copper - Posts: 192
Posted: October 06, 2005 at 9:03 AM / IP Logged
CHEVROLET, IMPALA, 2002, Power Lock
Lock and unlock use the same wire. Lock requires a negative trigger with a 470 ohm resistor in-line. Unlock is negative trigger. Must use relays.
The BCM is located above the brake pedal. It is a plastic box with three plugs that face the firewall.
ORANGE / black wire in gray 24-pin plug @ BCM
not sure if this is any help.
duley3
Copper - Posts: 73
Posted: October 06, 2005 at 9:14 AM / IP Logged
I know all that.. I have it hooked up the right way. Just some times after locking the doors the unlock does not work with the remote. Only if I wait awhile (over night or something) it won't work.
kgerry
Platinum - Posts: 3,455
Posted: October 06, 2005 at 10:00 AM / IP Logged
i've run into a few "sleepers" like that on GM vehicles.... it's almost as if a circuit goes to sleep... if you press lock then unlock in the morning it works fine, but if unlock only then it wont unlock....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Evolution-UK
Copper - Posts: 192
Posted: October 06, 2005 at 3:26 PM / IP Logged
If all else fails......
fit a door motor.
duley3
Copper - Posts: 73
Posted: October 07, 2005 at 7:37 AM / IP Logged
Okay here we go again. I have an 2002 Impala with the 562T remote start. 4 button remote. Lock, unlock, start, and AUX. I want the AUX button to open the truck. But I'm not understanding what wire(s) I need to work with on the unit. I know where the wires are on the car. Has anyone here hooked it up before? If so how would I go about it?
kgerry
Posted: October 07, 2005 at 1:32 PM / IP Logged
 LT.BLUE is the ( - ) trunk release relay input and is found at pin-A2 on the gray 24-pin C2 connector...hook this up to the RED / white aux  wire and off you go....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
duley3
Copper - Posts: 73
Posted: October 07, 2005 at 1:45 PM / IP Logged
I don't need to use any relays or anything? That sound easy enough... Thanks
Dave
duley3
Copper - Posts: 73
Posted: October 18, 2005 at 7:24 AM / IP Logged
Well I done just like you said.. LT blue to the RED / white wire and nothing happen. I even tried the RED / white wire to the wires at the switch (Black, BLACK/ White)
So what now? Do I need a relay or something? Please help this is the last thing I need to hook up. I have the door locks working, Horn working with  it, remote start works fine. I just need the truck to release now.
Page of 3
