1999 Cavalier Remote Start
Powermyster
Silver - Posts: 962
Posted: December 22, 2005 at 10:22 AM / IP Logged
on here type in arrow 5 and there is a few posts with links to manuals
Why oh Why didn't i take the blue pill
Darren Power
tbird2340
Copper - Posts: 363
Posted: December 22, 2005 at 10:37 AM / IP Logged
Thank you. I found one. The manual shows how to hook it up using two relays but doesn't show how to hook it up using a 451
Powermyster
Silver - Posts: 962
Posted: December 22, 2005 at 5:48 PM / IP Logged
the 451 is like the two relays in one unit and the switching of the relays is cone via the 3 pin locking harness..
so you will have 6 wires coming out com, n/o and n/c for each circuit.
I have never seen a 451 i'm just presuming its like a DLRM.
is there no manual with the 451. try search 451 on here
Darren Power
chris354
Silver - Posts: 253
Posted: December 23, 2005 at 12:14 AM / IP Logged
Heres how to wire the 451m for 5 wire locks.
Purple wire to 12volt
GREEN/ black to the motor side of the lock wire
WHITE/ black to the switch side of the lock wire
blue/black to the motor side of the unlock wire
BROWN / black to the switch side of the unlock wire
tbird2340
Copper - Posts: 363
Posted: December 23, 2005 at 10:03 AM / IP Logged
I need to remove the tilt lever on a Cavalier I'm doing so I can get to the passlock wires.. Does this thing just unscrew or what?? I can't seem to get it out!
gh057
Member - Posts: 19
Posted: December 23, 2005 at 10:05 AM / IP Logged
Get some vicegrips. Clamp them on right below the plastic right where it becomes metal. And they have loctite on it too. Spray some paint on and it'll be good as new.
tbird2340
Copper - Posts: 363
Posted: December 23, 2005 at 10:12 AM / IP Logged
So basically use some serious elbow grease?
tbird2340
Copper - Posts: 363
Posted: December 23, 2005 at 10:15 AM / IP Logged
Got it!! Thanks!!
sparkie
Platinum - Posts: 2,061
Posted: December 23, 2005 at 10:25 AM / IP Logged
Another trick to hide the paint damage is to use a small piece of heat shrink on the lever.
sparky
tbird2340
Copper - Posts: 363
Posted: December 23, 2005 at 11:43 AM / IP Logged
I'm having trouble finding the lock / unlock wires for this vehicle. Also, Directech says the wires are LOCK = LT BLUE and UNLOCK = WHITE however Wiremagic has LOCK = BLUE/GREEN and UNLOCK = BLACK/ RED.
Any idea which one is right and where I can find the bloddy things!??
Page of 3
