05 tacoma avic d3 wiring config
edwin8484
Member - Posts: 9
Posted: August 12, 2007 at 5:45 PM / IP Logged
Hi I just bout a pioneer AVIC-D3 Navigation system for my 05 Tacoma V6 ACC Cab 4x2 Auto, when I installed it I didn't connect the Pink Wired(Car Speed Signal Input) thinking I din't really needed it but after driving the truck for a little i notice the navigation gives me lots of error points, and I think its gotta do with this wire....so my question is , does anyone knows where in my truck is the speed detection circuit or to what wire I could hook this Pink wire from the D3 to my Truck?
I will really apreciate any help or lead to solve my problem!...Thanks
josh1979
Silver - Posts: 320
Posted: August 12, 2007 at 7:10 PM / IP Logged
12voltswht/blue (50A), wht/red (30A) + ignition harness
IgnitionBLACK/ red + ignition harness
Parking Lights+green + fuse box, 13 pin plug, pin 10
Parking Lights-green - headlight switch or BECU, pin 13
Notes: The Body ECU is attached to the back of the fuse box. It has a single 26 pin plug.
Headlightpink - headlight switch or BECU, pin 17
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Speed SensePURPLE / white fuse box, black 13 pin plug, pin 5
Notes: Also found at the ECM behind the glove box, second plug from the bottom, pin 8.
Wipersblue/black (L), blue/red (H) + windshield wiper switch
LF Window up/dnblue - blue/black A driver window switch in door
RF Window up/dnblue / YELLOW - black A driver kick, 12 pin plug, pins 2, 3
LR Window up/dnGREEN / WHITE - GREEN/ red A driver kick, 12 pin plug, pins 7, 1
RR Window up/dnGREEN/ black - green A driver kick, 12 pin plug, pins 5, 6
Sun Roof open/closeN/A
Sun Roof Limit/closeN/A
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
bring back the rotary phone so i dont have to press 1 to proceed in english
edwin8484
Member - Posts: 9
Posted: August 13, 2007 at 2:20 AM / IP Logged
Ok the  digram u gave me is wrong cuz I have already found what i was looking 4 and it works....thanx though!
edwin8484
Member - Posts: 9
Posted: August 13, 2007 at 2:21 AM / IP Logged
here is the link to my problem for anyone else that needs it
http://www.toyotanation.com/forum/t138609.html
edwin8484
Member - Posts: 9
Posted: August 13, 2007 at 2:22 AM / IP Logged
here is also some pics
05 tacoma avic d3 wiring config -- posted image.
edwin8484
Member - Posts: 9
edwin8484
Member - Posts: 9
Posted: August 13, 2007 at 2:25 AM / IP Logged
for reverse back-up camera use this wire
edwin8484
Member - Posts: 9
Posted: August 13, 2007 at 2:26 AM / IP Logged
edwin8484
Member - Posts: 9
Posted: August 13, 2007 at 2:28 AM / IP Logged
visit the web site I provided for better information on where to find the ECU and where to find the reverse back-up light wire.......Enjoy!
josh1979
Silver - Posts: 320
Posted: August 14, 2007 at 5:14 PM / IP Logged
ok the wiring was not wrong  your pic shows the same wire
