car audioicon
Car Audio / Passive Crossovers, High Pass/Low Pass Capacitor & Coil Calculator
Use these formulas to calculate for first, second, and third order low pass, high pass, and band pass filters. Do not use these for narrow band pass filter calculations.
Before clicking for the crossover component values, enter the impedance level and the desired crossover frequency. Values should be rounded off to the nearest hundredth.
If you need a 16 mHy coil, you can series a 12.8 mHy coil and a 3.2 mHy coil. If you need a 70 µfd capacitor, you can parallel two 35 µfd capacitors.When the exact value of a coil or capacitor is not available, you can substitute values of ± 5%.
Crossover Calculators:
High Pass/Low Pass Calculator
Narrow Band Pass Calculator
Zobel Calculator
Passive Crossover Capacitor and Coil Calculator
top of page Capacitor and Coil Calculator
Impedance Frequency
Ohms Hertz (Hz)
1st Order (6 dB per Octave) (diagrams)
L1 (mHy) = (1000 x Impedance) / (6.283 x Crossover Frequency) Coil - L1 Millihenries (mHy)
C1 (µfd) = 1,000,000 / (6.283 x Impedance x Crossover Frequency) Capacitor - C1 Microfarads (µfd)
2nd Order (12 dB per Octave) (diagrams)
L2 = L1 x 1.414 Coil - L2 Millihenries (mHy)
C2 = C1 x .707 Capacitor - C2 Microfarads (µfd)
3rd Order (18 dB per Octave) (diagrams)
L3 = L1 x 1.5 Coil - L3 Millihenries (mHy)
C3 = C1 x .1.33 Capacitor - C3 Microfarads (µfd)
L4 = L1 x .5 Coil - L4 Millihenries (mHy)
C4 = C1 x .667 Capacitor - C4 Microfarads (µfd)
L5 = L1 x .75 Coil - L5 Millihenries (mHy)
C5 = C1 x 2 Capacitor - C5 Microfarads (µfd)
<< Previous - Third Order Filters Next - Narrow Bandpass Crossover Formulas and Calculators >>
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
