car audioicon
Car Audio / Passive Crossovers, Zobel Filter Calculator
Use these formulas to calculate values of a capacitor and a resistor needed to construct a Zobel filter.
Before clicking for the capacitor and resistor values, enter the nominal impedance of the speaker and the frequency where the impedance has doubled. Capacitor values should be rounded off to the nearest hundredth.
If you need an 8 omh resistor, you can series two 4 ohm resistors. If you need a 3 µfd capacitor, you can parallel two 1.5 µfd capacitors. When the exact value of a capacitor is not available, you can substitute values of ± 5%.
Crossover Calculators:
High Pass/Low Pass Calculator
Narrow Band Pass Calculator
Zobel Calculator
Passive Crossover Zobel Filter Capacitor and Resistor Calculator
top of page Zobel Filter Calculator
Nominal Impedance Frequency Impedance Doubles
Ohms Hertz (Hz)
Zobel (diagram)
C (µfd) = 1,000,000 / (6.283 x Impedance x Frequency Impedance Doubles) Capacitor - C Microfarads (µfd)
R = 1.25 x Nominal Impedance Resistor - R Ohms
<< Previous - Narrow Bandpass Crossover Formulas and Calculators
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
