2000 FORD Superduty Diesel wire guide ?
Welcome Guest :)
Powerstroke
Member -
Posted: May 29, 2002 at 6:36 PM / IP Logged
Do any of you have the wire color guide for the 2000 Ford superduty truck with the powerstroke diesel motor ? Thanks
Moderator -
Posted: May 29, 2002 at 6:49 PM / IP Logged
Ford | Pickup/F250 & F350 | 1999-2001 |
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | RED / BLUE | IGNITION SWITCH HARNESS |
Ignition #1: | | | RED / BLACK (THICK) | IGNITION SWITCH HARNESS |
Ignition #2: | | | GRAY / YELLOW | IGNITION SWITCH HARNESS |
Ignition #3: | | | RED / BLK (THINNER) | IGNITION SWITCH HARNESS |
Accessory: | | | BLACK/ LT. GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | | LT. GREEN | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | WHITE/ PINK | AT BACK OF INSTRUMENT PANEL |
Parking Lights: | | | BROWN | AT LIGHT SWITCH |
Headlights: | | | | |
OEM Alarm Disarm: | | | DK. GREEN/ PURPLE (-) | IN DRIVER'S KICK PANEL |
OEM Alarm Arm: | | | ARMS WHEN VEHICLE IS | LOCKED WITH DR. DOOR OPEN |
Diesel Glow Plug: | | | BLACK/ PINK | AT BACK OF INSTRUMENT PANEL |
Clutch Bypass Wire: | | | | |
Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | YELLOW/LT. GREEN/ PURPLE | IGNITION SWITCH HARNESS |
Starter Kill: | | | RED / BLUE | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | | RED / BLACK (THICK) | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | BLACK/ LT. BLUE (-) | IN DRIVER'S KICK PANEL |
OEM Horn: | | | YELLOW /GREEN (-) | IN AIR BAG HARNESS |
Power Lock: | | | PINK / YELLOW | SEE NOTE #203 W/O KEYLESS |
Power Unlock: | | | PINK/GREEN | SEE NOTE #203 W/O KEYLESS |
Trunk Release: | | | N/A | |
Alarm Input Wire: | | | BLACK/ LT. BLUE (-) | IN DRIVER'S KICK PANEL |
Notes: | |
Thursday, October 31, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
