2007 ford f250 radio wiring
mrbeam07
Posted: May 02, 2011 at 8:40 PM / IP Logged
I'm looking for a detailed writing diagram. Including all wires not just the speaker and power wires.
ac0j
Copper - Posts: 121
Posted: May 02, 2011 at 9:33 PM / IP Logged
Are you doing something other than replacing the radio??   Power, ground, speakers. is all you need, unless you have a factory amplified system.  Any other wires to the factory radio would not be of much use for anything else.
mrbeam07
Posted: May 02, 2011 at 9:42 PM / IP Logged
Im just replacing the factory radio. im just wanting for it to have the delayed shutdown.
ac0j
Copper - Posts: 121
Posted: May 03, 2011 at 12:24 AM / IP Logged
you can do that with relays.  I saw the  diagram  posted on this forum a day ago.  I just dont remember where!  look for retained acsessory power.
Ween
Platinum - Posts: 1,368
Posted: May 03, 2011 at 6:08 PM / IP Logged
hi,
the delayed shutdown is a feature of the vehicle, not the radio.
the power windows and sunroof (if present) also share the same system.
wire the radio with an aftermarket harness and it will be fine.
mark
