stereo, 2002 chrysler sebring
big whitey
Posted: October 28, 2011 at 8:47 PM / IP Logged
Hey all,
I just "installed" a stereo in a car for a friend. He has a 2002 Chrysler Sebring. Of course I was dumb and didnt disconnect the battery before I did the install. Anyway now that the stereo is installed.. correctly I think (hard to get a proper diagram.. until I found this site) and his trunk release, power locks and stereo dont work. Does anyone have any suggestions of what I can do to fix this??
blanx218
Silver - Posts: 654
Posted: October 28, 2011 at 10:34 PM / IP Logged
check all fuses. there should be 2 fuse boxes in the car one on the driver side kick panel and one under the hood.
big whitey
Posted: October 29, 2011 at 7:01 AM / IP Logged
all the fuses in the kick box seem to be fine, the only ones we werent able to check were the ones under the hood for the ACC as we had no spare fuses
big whitey
Posted: October 29, 2011 at 10:05 AM / IP Logged
What fuses should he be checking, I am trying to do this over text message with him now. And am not familiar with this car. I already looked at the radio fuse and it is fine.
big whitey
Posted: October 29, 2011 at 10:34 AM / IP Logged
There were also 3 wires left over coming from the car... however every wire on the harness was used other than the power control / antenna wire, mute wire for bluetooth I assume and ant connection
buddholly
Copper - Posts: 244
Posted: October 29, 2011 at 11:39 AM / IP Logged
Infinity system will have two 10 amp fuses under the hood, #17 and #18
Without Infinity there will be two 10 amp fuses in the drivers end cap, #14 and #5
