Car Deck That Will Raise Power Antenna with Tuner Only?
namyenruoj
Copper - Posts: 64
Posted: June 25, 2020 at 2:25 PM / IP Logged Link to Post Post Reply Quote namyenruoj
Is there anyway to find out what car/stereo deck will bring up or down power antenna only when you listen to a radio station.
Ex. If I listen to a radio station power antenna will go up and then if I decided to switch over to bluetooth/CD the power antenna will go down.
the12volt
Administrator - Posts: 3,955
Posted: June 25, 2020 at 2:35 PM / IP Logged Link to Post Post Reply Quote the12volt
If installed properly, pretty much every new aftermarket car stereo on the market will raise the power antenna only when the tuner is on and lower it when you switch to any other source.
https://www.the12volt.com/caraudio/headunitharness.asp
Car Deck That Will Raise Power Antenna with Tuner Only? - Last Post -- posted image. the12volt • Support the12volt.com
Platinum - Posts: 13,675
Posted: June 25, 2020 at 7:17 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Most decks have only an amplifier turn on wire. Alpine decks have both an antenna control wire and a separate amplifier control wire.
the12volt
Posted: June 26, 2020 at 9:40 AM / IP Logged Link to Post Post Reply Quote the12volt
iaai, which popular manufacturers are you aware of that no longer have them?
Posted: June 26, 2020 at 10:36 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Most have done away with. Of the Pioneer, Sony, kenwood and JVC units I have on my board at the moment, none of those have a dedicated antenna wire. Just talked to my installer and he said the only thing he has seen in the last few years is Alpine.
namyenruoj
Copper - Posts: 64
Posted: June 26, 2020 at 12:55 PM / IP Logged Link to Post Post Reply Quote namyenruoj
Thank you for all your info really appreciated. I am thinking of buying this unit by Sony MEX-GS620BT for my 1998 Toyota Rav4 and I'm also buying a power antenna to go with it. I just like the idea of having your antenna extended while your listening to radio station if not it should stay down. Please let me know if this is possible.
the12volt
Posted: June 26, 2020 at 1:00 PM / IP Logged Link to Post Post Reply Quote the12volt
According to this info on Sony.com, it has a power antenna output.
Posted: June 26, 2020 at 9:06 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I have the gs620 on my display. It has only a blue/white. Granted the harness may be from the previous radio because I did not notice there was a separate wire for antenna. But the manual that is in the box that the radio came out of has only a blue/white. I will try to probe the empty slot tomorrow to see if there is an antenna wire.
namyenruoj
Copper - Posts: 64
Posted: July 02, 2020 at 12:46 AM / IP Logged Link to Post Post Reply Quote namyenruoj
I have decided to re-use my Alpine UTE-42BT instead but I have to install this brand new power antenna for my 1998 Toyota Rav4 today. It works, antenna goes up when i select radio and it goes down when I set to Bluetooth/USB and so on. I connect my power antenna wire to blue wire off the deck harness. Thank you guys. Car Deck That Will Raise Power Antenna with Tuner Only? - Last Post -- posted image.
Sunday, June 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
