2017 Kia Sedona, Remote Start Wiring
trowedder
Posted: October 09, 2020 at 5:19 PM / IP Logged Link to Post Post Reply Quote trowedder
requesting a wiring diagram with color and location of wire for a remote install for a 2017 kia sedona , thanks!
tr
trowedder
Posted: October 09, 2020 at 5:23 PM / IP Logged Link to Post Post Reply Quote trowedder
sorry key start
tr
tonanzith
Gold - Posts: 601
Posted: October 14, 2020 at 11:57 AM / IP Logged Link to Post Post Reply Quote tonanzith
2017 kia sedona
Item     Wire Color     Polarity     Wire Location
12 Volts     Red (40A)     +     Ignition Switch, black 6 pin plug, pin 1
Second 12 Volts     White (40A)     +     Ignition Switch, black 6 pin plug, pin 5
Ground     (chassis ground)
Starter     Black     +     Ignition Switch, black 6 pin plug, pin 3
Ignition     Green     +     Ignition Switch, black 6 pin plug, pin 4
Accessory     Blue     +     Ignition Switch, black 6 pin plug, pin 2
Second Accessory     Pink     +     Ignition Switch, black 6 pin plug, pin 6
Keysense     Pink/Black     -     Key Switch, white 6 pin plug, pin 4
CAN Bus High     Green (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     Orange (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus High 2     Blue (B-CAN)     Data     Driver Kick, black 60 pin plug (MF12), pin 27
CAN Bus Low 2     Red (B-CAN)     Data     Driver Kick, black 60 pin plug (MF12), pin 28
OBD 12 Volts     Gray/Black (7.5A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
IMMO Data     Blue (EMS COM)     Data     Driver Kick, white 46 pin plug (EM11), pin 32
K Line     White     Data     OBD-Data Link Connector, black 16 pin plug, pin 12
Power Lock     Orange/Black (passenger switch)     -     Passenger Kick, black 60 pin plug (MF22), pin 59
Power Unlock     Red/Black (passenger switch)     -     Passenger Kick, black 60 pin plug (MF22), pin 50
Lock Motor     Red     Reverse     SJB-Dash Fuse Box, white 38 pin plug (C), pin 10
Driver Unlock Motor     Green     Reverse     Driver Door Module-Window Switch, white 18 pin plug, pin 5
Passenger Unlock Motor     Brown     Reverse     SJB-Dash Fuse Box, white 38 pin plug (C), pin 9
Factory Alarm Arm     Brown/Black (see Tech Doc 1300)     -     Driver Door Module-Window Switch, white 32 pin plug, pin 4
Factory Alarm Disarm     Pink/Black (see Tech Doc 1300)     Double -     Driver Door Module-Window Switch, white 32 pin plug, pin 5
Lock Detection     Red/Orange (see Tech Doc 1300)     Open     Driver Door Module-Window Switch, white 32 pin plug, pin 3
Unlock Detection     (same as lock detection)     -
Parking Lights     Green/Black (L); Yellow (R)     +     SJB-Dash Fuse Box, white 38 pin plug (C), pin 35 (L); pin 34 (R)
Parking Lights -     Blue/Orange     - 1680 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
Parking Lights MUX     Blue/Orange     MUX     Headlight-Wiper Switch, black 16 pin plug, pin 14
Hazards     Pink     -     SJB-Dash Fuse Box, rear, white 32 pin plug (E), pin 18
Turn Signal (Left)     Yellow or White (LF); Gray (LR)     +     SJB-Dash Fuse Box, blue 31 pin plug (A), pin 5 (LF); white 40 pin plug (D), pin 16 (LR)
Turn Signal (Right)     White (RF); White/Black (RR)     +     SJB-Dash Fuse Box, blue 31 pin plug (A), pin 30 (RF); white 40 pin plug (D), pin 3 (RR)
Headlight     Blue/Orange     -     Headlight-Wiper Switch, black 16 pin plug, pin 15
AutoLights     Blue/Orange     Cut     Headlight-Wiper Switch, black 16 pin plug, pin 14
Reverse Light     Red     +     SJB-Dash Fuse Box, white 38 pin plug (C), pin 15
Left Front Door Trigger     Gray/Orange     -     Driver Door Module-Window Switch, white 32 pin plug, pin 13
Right Front Door Trigger     Yellow/Black     -     SJB-Dash Fuse Box, rear, white 32 pin plug (E), pin 19
Left Rear Door Trigger     Gray/Orange     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 19
Right Rear Door Trigger     Blue/Orange     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 39
Dome Light     Brown     -     Left Front Pillar, white 36 pin plug (MR11), pin 4
Trunk/Hatch Pin     White     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 13
Hood Pin     Pink/Black     -     SJB-Dash Fuse Box, blue 31 pin plug (A), pin 15
Power Liftgate     Green/Black     -     Passenger Kick, black 60 pin plug (MF22), pin 24
Trunk/Hatch Release     Gray/Black (rear handle switch)     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 14
Trunk Release Motor     Blue     +     SJB-Dash Fuse Box, white 38 pin plug (C), pin 25
Fuel Door Release     Pink     -     Fuel Lid Switch, black 6 pin plug, pin 5
Power Sliding Door (Left)     Pink (left center pillar switch)     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 12
Power Sliding Door (Right)     Pink (right center pillar switch)     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 11
Tachometer     Gray     AC     Camshaft Position Sensor, driver side of engine, black 3 pin plug, pin 2
Fuel Pump     Pink     +     Center Console, passenger front side, white 22 pin plug (EF11), pin 2
Rear Defroster     Green/Orange     - Latched     SJB-Dash Fuse Box, blue 31 pin plug (A), pin 4
Mirror Defroster     (B-CAN)
Wiper Deicer     Blue     - Latched     SJB-Dash Fuse Box, blue 31 pin plug (A), pin 6
Left Front Heated Seat     Brown/Black     -     Driver Kick, black 60 pin plug (MF12), pin 44
Right Front Heated Seat     Pink     -     Driver Kick, black 60 pin plug (MF12), pin 43
Speed Sense     Brown/Orange     AC     Radio, white 35 pin plug, pin 18 or white 38 pin plug, pin 38 or white 24 pin plug, pin 16
Brake Wire     Green/Black     +     Driver Kick, white 46 pin plug (EM11), pin 45
Parking Brake     Gray/Orange     -     Driver Kick, white 46 pin plug (EM11), pin 22
Horn Trigger     Red     -     Driver Kick, white 46 pin plug (EM11), pin 44
Wipers     Orange/Black     +     Driver Kick, white 46 pin plug (EM11), pin 7
Left Front Window (Up/Down)     White - Pink (w/o safety window only)     A     Driver Door Module-Window Switch, white 18 pin plug, pins 17 - 18
Right Front Window (Up/Down)     White - Pink (w/o safety window only)     A     Passenger Door Module-Window Switch, white 18 or 12 pin plug, pins 10 - 11
Left Rear Window (Up/Down)     Pink - Brown (w/o safety window only)     A     Left Rear Window Switch, white 8 pin plug, pins 1 - 2
Right Rear Window (Up/Down)     Pink - Brown (w/o safety window only)     A     Right Rear Window Switch, white 8 pin plug, pins 1 - 2
Sun Roof (Open/Close)     Red and Gray/Black (open) (functions with ignition on only)     Both -     Front Sunroof Switch, white 6 pin plug, pins 2, 3
Sun Roof (Limit/Close)     Gray/Black and Brown/Black (close) (functions with ignition on only)     Both -     Front Sunroof Switch, white 6 pin plug, pins 3, 4
Memory Seat 1     Blue     -     Driver Door Module-Window Switch, white 32 pin plug, pin 7
Memory Seat 2     Red/Black     -     Driver Door Module-Window Switch, white 32 pin plug, pin 8
Radio 12V     Pink or Red     +     Radio, white 35 pin plug, pin 10 or white 24 pin plug, pin 12
Radio Ground     Black     -     Radio, white 35 pin plug, pin 12 or white 24 pin plug, pin 24
Radio Ignition     Brown or Blue     +     Radio, white 35 pin plug, pin 22 or white 24 pin plug, pin 18
Radio Illumination     Red/Orange (parking lights); Blue/Orange (dimmer)     +,-     Radio, white 35 pin plug, pins 6, 19 or white 18 pin plug, pins 8, 17
Factory Amp Turn-on     (M-CAN)
Power Antenna     Green or Red     +     Radio, white 35 pin plug, pin 5 or white 18 pin plug, pin 18
Left Front Speaker (+/-)     Brown - White or Orange - Blue     +,-     Radio, white 38 pin plug, pins 13 - 14
Right Front Speaker (+/-)     Red - Blue or Blue/Orange - Yellow/Orange     +,-     Radio, white 38 pin plug, pins 16 - 15
Left Rear Speaker (+/-)     Yellow - Black or Pink - Green     +,-     Radio, white 38 pin plug, pins 1 - 2
Right Rear Speaker (+/-)     Green - Orange or Brown - White     +,-     Radio, white 38 pin plug, pins 28 - 27
Left Front Speaker - With Amp     Brown - White     +,-     Amplifier behind glove box, 28 pin plug (B), pins 15 - 28
Right Front Speaker - With Amp     Red - Blue     +,-     Amplifier behind glove box, 28 pin plug (B), pins 14 - 27
Left Rear Speaker - With Amp     Yellow - Black     +,-     Amplifier behind glove box, 28 pin plug (A), pins 15 - 28
Right Rear Speaker - With Amp     Green - Orange     +,-     Amplifier behind glove box, 28 pin plug (A), pins 14 - 27
Center Channel - With Amp     Red - Blue     +,-     Amplifier behind glove box, 28 pin plug (B), pins 13 - 26
Subwoofer - With Amp     White - Brown (coil 1); Blue - Red (coil 2)     +,-     Amplifier behind glove box, 28 pin plug (A), pins 13 - 26 (coil 1); pins 12 - 25 (coil 2)
Aux. Audio Input Left (+/-)     Blue - Black/Orange     +,-     Radio, white 38 pin plug, pins 24 - 25 or white 24 pin plug, pins 21 - 9
Aux. Audio Input Right (+/-)     Gray - Black/Orange     +,-     Radio, white 38 pin plug, pins 10 - 25 or white 24 pin plug, pins 8 - 9
Rearview Camera Video     Red - Black or Yellow - White (w/o surround view monitor)     +,-     Radio, white 38 pin plug, pins 7 - 21 or white 24 pin plug (C), pins 23 - 22
Gary Sather
Sunday, June 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
