rs-850lcd?
almeida79
Member - Posts: 47
Posted: August 14, 2003 at 6:17 AM / IP Logged
          I'm planing on buying an autopage rs-850lcd alarm/starter and what i need to know is what buttons on the lcd remote control the auxilary  outputs of the alarm. for example which buttons for what aux outputs I want to add a few features like windows up and down. Also when i hold the button down for a momentary aux output will it bypass the shock sensor for however time i hold the button down and the output is active. I can't find an online manual  so i could look for this info. Thanks in advance.rs-850lcd? - Last Post -- posted image.
Jay
cpgoose
Gold - Posts: 1,098
Posted: August 14, 2003 at 8:55 AM / IP Logged
I couldn't find a manual either. Try going to their website, and emailing the support, and ask for the manual. They should be able to send you one, or direct you to one online.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
jrilla
Gold - Posts: 1,498
Posted: August 14, 2003 at 10:56 AM / IP Logged
Go here, this is the same unit.
Commando FM-870
In the Red box on the left column there are links to the install and Owners manuals.
J Rilla
Owner/Installer
Manokat
Member - Posts: 12
Posted: August 14, 2003 at 1:52 PM / IP Logged
Yup they are the same. I have rs-850 and I've check the pdf files on that site.
almeida79
Member - Posts: 47
Posted: August 14, 2003 at 1:57 PM / IP Logged
Is it just the remote thats the only diference then and does the starter kill also act as an antigrind feature
Jay
Monday, September 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
