Pop Trunk on the Cadillac
Cadillakin
Member - Posts: 19
Posted: February 13, 2004 at 9:00 AM / IP Logged
I have installed a Clifford RSX 3.5 on my 1994 Cadillac Deville. (Took me 3 Days). Installation manual says to use the  RED / white wire for the trunk actuator. It sends a negative signal, so that means that i need a relay right? Ok, So i bought a relay and the guy at the installation place told me to check of it has a resistor on it otherwise it will work several times the damage something. So I tried checking the voltage going in to the solenoid and the signal comes and goes so fast that the multimeter doesn't get a reading. I tried using the ac voltage meter I got a peak reading of .6 volts. What is going on? I don't whant to mess anything up.
Moderator - Posts: 12,488
Posted: February 13, 2004 at 9:24 AM / IP Logged
Don't be too concerned with the resistor between the coils. I have done many installations without this resitsor and have had no problems with my customer's vehicles causing problems.
Cadillakin
Member - Posts: 19
Posted: February 13, 2004 at 9:43 AM / IP Logged
So I just hook up the Relay like I would on anything else?
Positive on 85 and 87.
RED / White on 86
and solenoid lead to 30.
Posted: February 13, 2004 at 10:03 AM / IP Logged
Here is the color and location: TRUNK/HATCH RELEASE----------BLACK/ white-------------at the trunk release motor and use this diagram to convert the signal to a (+) from a (-) : http://www.velocitymotorsport.com/images/install_notes/N2P.jpg
Cadillakin
Member - Posts: 19
Posted: February 13, 2004 at 6:04 PM / IP Logged
OK I did it. Done. Gracias.
