Intake Air Temperature for 97 Accord
lilvmpr
Posted: June 19, 2004 at 2:44 AM / IP Logged
Does anyone know where exactly is the IAT (intake air temperature) locate in an 97 Accord?  Also, does changing the load (add a resistor) of the IAT help increase the output performance of the car?
auex
Platinum - Posts: 5,041
Posted: June 19, 2004 at 10:35 AM / IP Logged
First, it is in the intake, hence intake air temp sensor. Second, that whole deal is pretty much a scam and doesn't really do anything. If you want to increase the performance of the car then YOU should take it to someone to do anything, sorry but it doesn't sound like you know anything about the engine in the car.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
blindxp
Member - Posts: 19
Posted: June 19, 2004 at 1:23 PM / IP Logged
colder air in your engine makes more power, telling your car that colder air is there wouldn't do much.
Try getting someone to make you a cold air intake that will run down to the front of the car. I had a friend lose a fog light and put his intake inlet right there.
lilvmpr
Posted: June 19, 2004 at 1:24 PM / IP Logged
Thanks for the heads up.  And you're correct, have no experience with car engine, but i'm open to learn new things.
itmdtr
Copper - Posts: 131
Posted: June 19, 2004 at 1:46 PM / IP Logged
Installing a resistor in place of the IAT makes the computer think that the air is colder (at a fixed temp).
Colder air  = more fuel (the injectors pulse width is widened introducing more fuel to the engine)
Some people think that there is an increase in HP, but I don't think it's enough to have an decrease in fuel milage.
As above: Get a "cold" air intake, not one of those that just sucks air from the engine compartment.
itmdtr
