2001 Ranger Diagram
ErikJL78
Posted: September 13, 2002 at 7:40 PM / IP Logged
Is the 2000 the same as the 2001 as far as wiring goes? I took apart my steering column to find a funky litle box with 4 26ga wires, and a black 12ga wire coming from it. Not the usual ignition wires, and I'm not sure if I can put the starter interrupt relay near the column like I wanted to.
Moderator - Posts: 12,488
Posted: September 13, 2002 at 7:57 PM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|lt. GREEN/ purple    |+  |ignition harness            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ lt. green     |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |-  |driver door harness or PKP  |
|     POWER UNLOCK|pink/lt. green *4   |-  |driver door harness or PKP  |
|       LOCK MOTOR|pink/black          |   |driver door harness         |
|     UNLOCK MOTOR|RED / orange          |   |driver door harness         |
|    DISARM DEFEAT|pink/orange         |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |headlight switch or GEM *1  |
|       HEADLIGHTS|RED / yellow          |+  |headlight switch            |
|     DOOR TRIGGER|*2                  |-  |GEM *1                      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|tan / YELLOW          |   |instrument cluster or PCM *3|
|      SPEED SENSE|gray/black          |   |GEM *1                      |
|       BRAKE WIRE|lt. green           |+  |brake pedal switch          |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column             |
|           WIPERS|wht (L), blu/org (H)|+  |windshield wiper motor      |
|  LF WINDOW UP/DN|wht/blk - red       |A  |driver window motor         |
|  RF WINDOW UP/DN|wht/yel - tan/lt blu|A  |driver door harness or PKP  |
|        RADIO 12V|lt. GREEN/ purple    |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/black        |+  |radio                       |
| RADIO ILLUMINATE|lt. blue/red(dimmer)|+  |radio                       |
|       LF SPEAKER|org/lt grn-lt blu/wh|   |radio                       |
|       RF SPEAKER|wht/lt grn - grn/org|   |radio                       |
|       LR SPEAKER|gry/lt blu - tan/yel|   |radio                       |
|       RR SPEAKER|org/red - brn/pnk   |   |radio                       |
Notes:
NOTE:  This vehicle is equipped with PATS (Passive Anti-Theft System).  Use DEI module 555U to over-ride during remote start.  *1 The GEM (Generic Electronic Module) is to the left of the radio.  *2 The driver door trigger is yellow/black and the passenger door(s) is gray/red. Use both wires and diode isolate as shown in directfax document #1076.  *3 The PCM (Powertrain Control Module) is on the top of the firewall under the hood towards the passenger side. The tachometer wire is in pin 48. Can also get tach at the ignition coil or coil pack. Use any of the tan/stripe wires.  *4 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to "wake-up" the system refer to directfax document #1093.
