Need input on Box Design
Klondike
Member - Posts: 6
Posted: December 06, 2004 at 3:03 PM / IP Logged
I registered to this forum becaue I can see there are many active members who have a ton of experience. I hope that some of you can chime in and give me some valuable input towards my project.
I am designing a box for a Brahma 12 subwoofer. I will be running this sub with a very small JL audio 500/1 amplifier.  This is going into the hatch of a 1997 Toyota Supra.  I will have some additional output due to using the hatch.  I am trying to maximize my output with very little or no comprimise in SQ.  I have narrowed down my enclosure design to two boxes.  The first choice is a classical sealed enclosure 1.25 to 1.5 ft^3.  The second is a ported box 2 ft^3 at 25 Hz tune. I was considering a 2ft^3 at 3 Hz tune but after looking at the graphs in WinISD Pro it looks like that it may be a little too boomy and have a less flatter response. Also the graph has some peaks in it that I think could cause some problems.  The ported boxes were calculated using a 4 inch circular port.
I would really appreciate anyone with some advanced knowledge/experience on this topic to chime in. Which box do you think would work best for my application. I want a good amount of SQ with some decent output.
forbidden
Platinum - Posts: 5,353
Posted: December 06, 2004 at 3:44 PM / IP Logged
I would await to hear from Stephen Kephart, he is our local expert on Adire Audio as he is employed with them. Do a search for his name and send him a PM on it. Had I been an Adire dealer, I most certainly would have sent you some info. You are in good hands with his advice.
Klondike
Member - Posts: 6
Posted: December 06, 2004 at 5:52 PM / IP Logged
I have actually spoken with someone from Adire on the phone but was referred to email their tech department about some of my ported box design questions.
The tech department has answered a lot of my questions and have actually led me to the point where I am trying to decide between these two options.
I am not looking for a general answer that sealed gives more SQ and ported gives more SPL.  I am trying to figure out how to build a ported enclosure that will yeild excellent SQ so that I can take the most advantage of the limited 500 watts I am throwing at it and also take advantage of the environment of my car.
Thanks.
kfr01
Gold - Posts: 2,121
Posted: December 06, 2004 at 6:53 PM / IP Logged
I'm assuming 3 Hz tune should have been 30hz????
If so, then yes, you'd need to increase the box size, maybe 3ft^3 to kill hump you saw.
For SQ I'd pick the 25hz tuning frequency over the 30hz one.  Less of the frequency spectrum will be below the tuning frequency, resulting in less distortion during low bass tracks.
New Project: 2003 Pathfinder
Klondike
Member - Posts: 6
Posted: December 06, 2004 at 7:23 PM / IP Logged
Yes sir! That should have said 30Hz tune.
jeffchilcott
Platinum - Posts: 2,483
Posted: December 06, 2004 at 7:26 PM / IP Logged
i would definattly stay withen 25-28 hz if you sre trying to reamin very clean.   also look at how fast the air will be moving through your port known as vent mach...if your getting high then you will get distortion or port noise, I have found that vents are the easiest to keep a clean sound
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Klondike
Member - Posts: 6
Posted: December 07, 2004 at 12:29 AM / IP Logged
Is there a certain port velocity that I need to not go over????
thanks
