DIRECTWIRE™ WIRING INFORMATION - ACURA / LEGEND / 1992 / Remote Start
12volts white + ign harness or fusebox
Starter BLACK/ white + ign harness or fusebox
Second Starter
Ignition BLACK / YELLOW + ign harness or fusebox
Second Ignition
Third Ignition
Accessory yellow + ign harness or fusebox
Second Accessory
Keysense
Power Lock GREEN / WHITE - door lock module
Notes: Door lock module and factory anti-theft mounted together between column and center console above the accelerator pedal - can also use BLACK/ white and BLACK/ red here for locks.
Power Unlock GREEN/ red - door lock module
Lock Motor
Unlock Motor
Parking Lights+ RED / black dr. kick panel/fusebox
Parking Lights- RED / green at steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger wht/blk or blk/wht - plug above dr. kick
Dome Supervision
Trunk/Hatch Pin GREEN/ black - plug back of cluster
Hood Pin yellow/red - at anti-theft module
Trunk/Hatch Release WHITE/ black + dr. kick/rear harness
Power Sliding Door
Factory Alarm Arm GREEN/ YELLOW - at anti-theft module
Factory Alarm Disarm GREEN/ red - at anti-theft module
Disarm No Unlock
Tachometer blue/silver dots AC back of dash or
Notes: Tach wire located at 12-pin green plug at back of instrument cluster, or at tach test connector by passenger side shock tower - single wire w/plug.
Wait to start
Brake Wire GREEN / WHITE + brake pedal switch
Parking Brake
Horn Trigger blue/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - ACURA / LEGEND / 1992 / Audio
[PRINT THIS PAGE]
Radio 12v WHITE/ yellow + radio
Radio Ground black - radio
Radio Ignition yellow/red + radio
Radio Illumination RED / black + radio
Factory Amp Turn-on
Power Antenna yellow/white + radio
LF Speaker +/- blu/grn - gry/blk radio
RF Speaker +/- RED / grn - brn/blk radio
LR Speaker +/- blu/yel - gry/wht radio
RR Speaker +/- RED / yel - brn/wht radio
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - BMW / 3 SERIES / 1994 / Security
[PRINT THIS PAGE]
12volts RED / wht or red + ignition harness
Starter blk/yel or grn/blk + ignition harness
Ignition green + ignition harness
Power Lock WHITE/ red + factory alarm plug
Notes: The alarm plug is a black 12 pin plug located just behind the glove box. It is mounted with the pins facing you atop a vent just to the left of the body computer. Other wires at the alarm plug are: 12V- RED / white; Accessory- PURPLE / white; Siren- BLACK/ blue; Ground- BROWN / orange; Do not use the power sources at the alarm plug to operate high-current devices. The other side of the siren wire is mounted in a 2 pin plug at the passenger rear corner of the engine compartment. The other wire in the plug is a brown ground wire. DEI recommends attaching the siren at this point.
Power Unlock blue/red + factory alarm plug
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ gry/pur, gry/yel headlight switch
Notes: These wires are the separate left and right parking light wires. Use both wires and isolate each.
Parking Lights- blue/green (hazards) factory alarm plug
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger - factory alarm plug
Door triggers are BROWN / gray for the drivers front door, BROWN / blue for the passenger front door, and BROWN / white for the rear doors (if equipped). Use all three wires and diode isolate each. If the left rear door does not trigger your alarm system, then remove the diode on the BROWN / white.
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / white - factory alarm plug
Hood Pin PURPLE / green -
Notes: On early production models the hood pin wire can be found at the radio harness or at the hood pin switch. On later models the hood pin is located in a single pin connector next to the factory alarm plug.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Notes: If equipped with a factory alarm, the alarm will be plugged into the factory alarm plug. The only way to arm and disarm the factory alarm is with the factory remote. If your planning on using the 8360 pre-wired alarm harness the factory alarm must absent or removed.
Disarm No Unlock
Tachometer black AC instrument cluster
Notes: The wire is located in a white connector behind the instrument cluster. Do not unplug the white connector with the ignition on or turn the ignition on with the plug disconnected.
Horn Trigger BROWN / red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.
