honda odessy
camino
Copper - Posts: 54
Posted: November 23, 2002 at 7:09 PM / IP Logged
i have some problem with the remote start  and the sliding door,i did the remote start using the factory keyless,with the 700t,and the valet 550,for remote start,ok.but when the vehicle is runing under the remote start,the keyless entry dont work,because of the  bypass module 555f is sending the sense key pulse to the keyless entry module,i  cut the wire that goes to the keyless module but did not work,so if somebody knows the secret please let me know,thanks.  my email is
joseg224@hotmail.com
el camino
securinu
Silver - Posts: 772
Posted: November 24, 2002 at 8:08 PM / IP Logged
list your email and and i will send you a pdf on oddysey you can use dei remote to cure the problem.
hpham240sx
Posted: December 05, 2002 at 8:42 PM / IP Logged
 hey i dont what year of odysey you are working on , but i have the same problem on 2002 . you have to bypass the factory alarm . the module located in the driver door panel , if im not wrong the wire is blue ,conect that blue wire to the remote system ,to the wire that is ground when running. hope that i've help you, good luck
