How to wire a relay for normally closed
noooorb
Member - Posts: 17
Posted: May 12, 2006 at 1:16 PM / IP Logged
Hey guys I know a typical automotive relay works in the way that if there is current in one circuit it will switch annother circuit so current will flow through that one.
Is there a way to wire the relay so that there is current normally flowing through the circuit that is getting switched, and once it swicthed (as in the controlling circuit is flowing), then it (the circuit that gets switched) gets switched off?
Sorry the above may have been confusing
Aruman
Silver - Posts: 363
Posted: May 12, 2006 at 1:57 PM / IP Logged
most of the relays come with N/O Normaly Open and N/C Normaly Close just what you looking for, heres a sample pic how to connect it. and read this
hope it helps.
How to wire a relay for normally closed - Last Post -- posted image.
Shaking The Neighborhood
Wednesday, September 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
