1983 accord clock
mobilecustoms
Silver - Posts: 397
Posted: November 29, 2006 at 11:05 AM / IP Logged
i want to wire this car clock to work in my home like the other car clock previously posted
the color wires are:
yellow with red dots
white with blue stripe and two red dots
black
red with black stripe with black dots
red with black dots
master5
Silver - Posts: 1,123
Posted: November 30, 2006 at 2:04 AM / IP Logged
Yellow/red is accessory..so if you want the clock on all the time that will go to 12v+ constant
WHITE/ blue goes to constant 12v as well.thats the memory so it holds the time when the key is off.
RED / black is illumination...when you apply 12v to this wire the clock display should dim..this is so it's easier to see in the day..and not so bright at night..you decide if you want it or put it on a switch so you can choose.
that leads me to believe the RED / black dots is negative, however I am not 100%, I am going by hondas wiring from 83..damn thats old..and the only info I have for ground is chassis..I guess if it don't work try switching the RED / black and RED / black dots to negative
mobilecustoms
Silver - Posts: 397
Posted: November 30, 2006 at 7:30 AM / IP Logged
thanks i got it working
