Viper 5900, sensor, door locks
heyitzalan
Member - Posts: 14
Posted: January 03, 2007 at 8:52 PM / IP Logged
Hi, i just ordered a viper 5900, and it only come with stinger double shock sensor. Anybody have clue how to add one or more sensor like tilt or glass sensor  with the stinger double shock sensor?
HELP! Viper 5900, sensor, door locks - Last Post -- posted image.
profuse007
Gold - Posts: 2,015
Posted: January 03, 2007 at 9:37 PM / IP Logged
its plug and play. there should be two more ports for sensors.
Houston,TX
Ravendarat
Platinum - Posts: 2,806
Posted: January 03, 2007 at 9:38 PM / IP Logged
Or if you get a piece thats not dei you can add it on using the multiplex blue input wire on the brain or using the green wire on the shock sensor side of the harness for instant trigger. You have many options here.
heyitzalan
Member - Posts: 14
Posted: January 03, 2007 at 9:42 PM / IP Logged
there is only one "shock sensor" port, nothing else.
profuse007
Gold - Posts: 2,015
Posted: January 03, 2007 at 9:46 PM / IP Logged
appologize for that. i was thinking of 5000 brain but you can wire it through the shock sensor like above mentioned.
Houston,TX
heyitzalan
Member - Posts: 14
Posted: January 03, 2007 at 9:51 PM / IP Logged
i only have power(red), ground(black), alarm negative output(blue), and warn negative output(green) wires in the shock sensor port, i want to add tilt and glass sensor along with the same wire, how can i do that?
heyitzalan
Member - Posts: 14
Posted: January 04, 2007 at 11:06 PM / IP Logged
anyone know?
heyitzalan
Member - Posts: 14
Posted: January 13, 2007 at 4:40 PM / IP Logged
I have solder my actulator to my viper + and - wire to the brain. i press arm and disarm it won't lock or unlock my actulator. All it does is beep, and beep beep.
