2008 impala onstar
audiomaninc
Copper - Posts: 108
Posted: April 25, 2008 at 9:46 AM / IP Logged
Hello, I've got a question.  I installed an OS3-Bose into a 2008 Impala, and later installed a 4-channel amplifier, and now the Onstar doesn't work.  Well...it works, but it can't be heard.  I assume that I can just install a single speaker for the onstar under the dash somewhere, but do I just connect that to the OS3-Bose harness?  Thanks!
Jason @ AudioMan
2003 Dodge Neon R/T
Alpine CDA9813, RF T2000.1bd, RF T162S, RFT142C, RF T600.4, RF T215D4
140.7 @ 28Hz
Moderator - Posts: 12,488
Posted: April 25, 2008 at 11:33 PM / IP Logged
The OnStarŪ volume is controlled from the adjustment screw on the interface. Make sure this is set to the desired level before
mounting the interface and reassembling the dash.
extreme1
Silver - Posts: 1,070
Posted: April 26, 2008 at 11:05 PM / IP Logged
when you added the amp you eliminated the onstar audio as it normally comes out of the left front speaker.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
audiomaninc
Copper - Posts: 108
Posted: April 27, 2008 at 11:36 AM / IP Logged
I understand that I eliminated the audio...now I want to get it back.  Does anybody know of a way to do this without adding an external speaker?
Jason @ AudioMan
2003 Dodge Neon R/T
140.7 @ 28Hz
