too much power?
thatfloorguy
Copper - Posts: 95
Posted: May 14, 2009 at 8:58 PM / IP Logged
 I am building a 6 cubic foot slot port enclosure to Kicker specs for an 08 L7 15 4 ohm (wired to 2). Did the Big 3 last year so I am getting a steady 14 volts to an 08zx750 to power it. The sub will take 750 in this enclosure. Will the amp be too much? It is certified @ 926 @ 14.4 volts. I have blown 2  12 L7's (older models) on seperate occasions. I assume due to port /enclosure size.
choff86.5
Member - Posts: 8
Posted: May 14, 2009 at 9:27 PM / IP Logged
make sure it doesnt distort and your fine
thatfloorguy
Copper - Posts: 95
Posted: May 14, 2009 at 9:34 PM / IP Logged
gonna start w/ gain and bass boost all the way down on the amp and sub volume on head unit down  -24 i think it goes to  pioneer deh 4900 pioneer 6x9's,5 1/4's in the rear and  6 1/4's and tweets up front  08zx350.4      08zx750.1    back half of car completely dynamatted so far.
aznboi3644
Gold - Posts: 2,600
Posted: May 14, 2009 at 11:22 PM / IP Logged
6 cu ft is a little big IMO for that sub.
Custom Enclosure Design
thatfloorguy
Copper - Posts: 95
Posted: May 15, 2009 at 5:49 AM / IP Logged
I had considered the 4.5 but it also drops the RMS om 1000 to 750 and I am already giving up my trunk for the sub. The 6 is the largest rec0mmended SPL enclosure for the 15 (Kicker recommended) I just thought the 6 will produce more low end deep bass. any suggestions will be taken with pleasure, as I said I have locked up 2 older L7 12's  with this amp.(gain set to almost nothing)
thatfloorguy
Copper - Posts: 95
Posted: May 15, 2009 at 6:03 AM / IP Logged
I also would like to have the port rear firing w/ the sub. Will that be ok as long as I don't change the volume or size? The side firing will be too close the trunk interior I fear. The spec sheet calls for it to be behind the sub. @ 550 a pop I don't wanna blow this one.
aznboi3644
Gold - Posts: 2,600
Posted: May 15, 2009 at 11:35 AM / IP Logged
Do 4.75 cu ft net tuned to 33Hz with around 65 sq in of port area. It will take 1000 watts all day.
I had a 15L7 in a 4.2 cu ft aperiodic bi-chamber enclosure and it took 900 watts rms all day no sweat. Heres it playing a 10Hz tone.
15L7 10 cycles ~500 watts
thatfloorguy
Copper - Posts: 95
Posted: May 15, 2009 at 7:19 PM / IP Logged
Thanks Man, Now I can adjust the size too the 17  3/4 high was gonna be a bi*** to get in a 96 cav even removing the back seat
ianarian
Copper - Posts: 516
Posted: May 15, 2009 at 7:20 PM / IP Logged
Before I die I hafta blow at least 1 decent woofer up..... I have never blown one, but it sounds fun. :/
thatfloorguy
Copper - Posts: 95
Posted: May 15, 2009 at 7:45 PM / IP Logged
depends on what ya pay for it and the time to build the box, wether it is fun or an expensive mistake.
Page of 4
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
