vss wiring
black33
Posted: January 06, 2010 at 7:44 PM / IP Logged
I am trying to install a 1995 camero cruise control unit into a street rod with a 1992 camero drive train. I have the vss supplying a signal
to the ecm and the speedometer with no problems. I would now like to tap into the vss wiring to supply the cruise control but have not been able
to get a signal to the CC. The output for CC on 3 different ECM's don't give me a signal. My questions are : how can I connect the CC to the vss.
Can I even run a number different of accessories from one VSS without some type of splitter
Thank you in advance for any help
mustyk@att.net
Copper - Posts: 132
Posted: January 15, 2010 at 7:13 AM / IP Logged
Typically the VSS wire is dark green@ the instrument cluster. But check to see if the speedo is mechanical (CABLE DRIVEN) or electronic
thetopinstaller
mustyk@att.net
Copper - Posts: 132
Also color could be Dk GREEN / WHITE stripe
thetopinstaller
KPierson
Platinum - Posts: 3,527
Posted: January 15, 2010 at 8:01 AM / IP Logged
You should not need a splitter as long as the devices you are connecting to the VSS are high impedence (which they should be).
You also need to make sure the pulse outputs are the same, although it probably won't actually matter much with cruise control (since actual speed isn't important in most cases).
Kevin Pierson
