Clifford Wiper and Sunroof Wiring on Acura Integra
sleepy186
Member - Posts: 9
Posted: June 09, 2002 at 1:47 AM / IP Logged
I have a Clifford AvantGaurd 4 alarm, and I need to do an install on an 1998 Acura Integra LS.  The wires I'm having trouble wiring the sunroof to open and close with the auxilary output that grounds for a preset amount of time.  Also for the wiper input and output, which ones should I use coming from the wiper switch?
Moderator - Posts: 12,488
Posted: June 09, 2002 at 10:12 AM / IP Logged
  • IF you are wanting to open and close the sunroof via remote control you will need to add window modules and each module will need it's own ( - ) trigger from the alarm.
  • As far as the wipers go you need to use both wires ( BLUE & BLUE / YELLOW ) and diode isolate each wire form the alarm using a 4001 diode. You can get these at any electronics stor or Radio Shack.
  • The sunroof wires are :
    • CLOSE : GREEN/ YELLOW
    • OPEN : GREEN/ RED
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
