remote start, factory remote, 08 accord?
Mike M2
Platinum - Posts: 2,652
Posted: November 16, 2010 at 8:02 PM / IP Logged
Now now, re-read the very first line....
Mike M2
Tech Manager
CS Dealer Services
08accord
Member - Posts: 12
Posted: November 17, 2010 at 11:24 PM / IP Logged
Hey everyone thanks for your inputs.. I just finish installed the viper 5902/DBALL everything works great..i didn't bother with the oem remote start..I also run into another problem is that my headlights doesn't turn off when the remote start time is over. I have Auto Headlights
Here is my connections.
DBALL
Car
IMMO Data - Orange
Lt.Green
CAN High - Tan/Black
Pink
CAN Low - Tan
Blue
Ignition input - Pink
Yellow
Alarm
Heavy Gauge H3 10 Pin Harness
    Pink - Ignition Input/Output
Blue
    RED / White - Flex Relay
White
    Orange - 1st Accessory
Orange
    Violet - Starter
Yellow - car side
    Green - Starter
Yellow - key side
    Red - Ignition Input 1
White - Constant 12V
    Pink/white - 2nd Accessory
Red - 2nd Accessory
    RED / Black
Primary H1 12 Pin Harness
    Red - Constants 12V Input
    Brown - Siren
Siren
    Black - Ground
chassis
    White - Parking Light Output
Gray - Parking Light (-)
Here is an interesting point in DBall Instruction its say connect the rearm to parking light for Auto Headlights Vehicle
So I connected the H2/2 Lt.GREEN / WHITE (-) 200mA Factory Alarm Arm Output to the Parking Light wire. I tested it without connect it to the vehicle parking light wire. I noticed that if I DON'T connect the wire and when I pressed the Start bottom to disengage the remote start it doesn't turn off the headlight. Now when I connected the wire to the parking light and pressed the Start bottom to disengage the Remote Start it turned off the headlight. My Question is why doesn't it turn off the headlight when the remote start time is over auto shut down? Thanks again everyone.
Mike M2
Posted: November 18, 2010 at 6:23 AM / IP Logged
The factory arm output wire should go to the drivers door pin wire. This way it thinks the door opend once and starts the timed autolight sequence...
Mike M2
Tech Manager
CS Dealer Services
08accord
Member - Posts: 12
Posted: November 18, 2010 at 11:01 AM / IP Logged
Hey Mike Thanks for the replied but wouldn't that make the alarm think that someone is open the door and set off the alarm?
08accord
Member - Posts: 12
Posted: November 18, 2010 at 12:50 PM / IP Logged
OK so after I hooked up the Driver Door Pin to the - factory output I have to press Lock twice to get the Door lock to lock.. Is there any feature in the alarm that I have to set to get it to work? Thank.
08accord
Member - Posts: 12
Posted: November 18, 2010 at 7:08 PM / IP Logged
Someone help me please everything is done except for the auto headlights.
tedmond
Gold - Posts: 4,610
Posted: November 19, 2010 at 6:48 AM / IP Logged
auto headlights turn off after 1 minute.
I know this for a fact because i have the 09 accord, and did a full writeup for it in downloads.
you have 2 options:
1: pulse your door pin and it will turn off the headlights.
2: pulse ground (rearm wire make sure you place a diode on this line just incase) which is RED (-) headlight switch in a < size=1 face=Helvetica>< size=1 face=Helvetica>BLACK/ white 12 pin plug, pin 9
Ted
Compustar Expert
08accord
Member - Posts: 12
Posted: November 19, 2010 at 4:40 PM / IP Logged
Alrite thanks everyone..I tap it to the red wire with a diode and the headlight turned off after 1 min or so..but for some odd reason when I remote start it quickly unlock and lock back again.hmm I'm wondering if it the RED wire that trigger it..I think I can live with it as long as the thieves are not smart enough and monitor my door locks when I remote the car and open the door quickly enough before it start locking again..
08accord
Member - Posts: 12
Posted: December 03, 2010 at 8:43 PM / IP Logged
Hello again everyone..I started a thread here last time about a 2008 Honda Accord with a Viper 5902 and a Xpresskit DB-All by D2D. Everything works good until today. I installed this setup for my sister car. I don't know what she did but now she CAN'T start the car with the KEY anymore, it started but immediately shut down afterward. Remote Start works, so the only way to start the car now is with Remote Start then put the Key in then it won't shut off. Please everyone if you experience this problem before please give me advise on the problem/s so I can get it back to normal again. Thank you all for you time.
Platinum - Posts: 7,802
Posted: December 03, 2010 at 9:54 PM / IP Logged
Never had this problem but it sounds like the DB-ALL is on all the time.  Check the Vipers' D2D jumpers are set to External.  Verify the D2D cable is fully seated at both ends.  Check the DB-ALL Pink Ignition wire connection.  Try a DB-ALL reset by re-programming it.
Page of 3
