2009-2011 Toyota Yaris Remote Starter Pictorial
Platinum - Posts: 7,786
Posted: January 02, 2012 at 2:53 PM / IP Logged
This is a pictorial for the 2009 - 2011 Toyota Yaris for a basic remote starter install.  These pictures are
from a 2011 5 door with no power locks or windows.  This car did have Automatic Transmission and A/C.
No transponder based immobilizer was installed.
Disassembly :  Remove the drivers lower dash panel by pulling at the top - straight away.  There are 6 retaining clips.
The panel is hinged at the bottom and folds down.  Open the storage bin and remove by squeezing the top sides
in and pull out.   Then pull the bin straight away at the bottom hinge exposing the Dash Fuse Box.
2009-2011 Toyota Yaris Remote Starter Pictorial -- posted image.
Remove the lower Steering Column cover by removing one Phillips screw at the bottom and two Phillips screws at
3 and 9 o'clock by rotating the steering wheel right & left.
Picture of Ignition Switch on right side of steering column with lower cover removed.
Picture of Ignition connector.  Small gauge wires.
Picture of Headlight switch connector in steering column.
Picture of Brake Pedal Switch connector above brake pedal.
Picture of Dash Fuse Box.
Picture of Brake(+) at Dash Fuse Box.  Close-up.
Picture of OBD2 diagnostic connector.  The Tach wire is at Pin 9 and can be Beige or Light Green.  Tach is also available
at any Fuel Injector, non-common color wire.
metz35
Copper - Posts: 458
Posted: January 02, 2012 at 3:34 PM / IP Logged
Nice! +1
ziggyb222
Silver - Posts: 593
Posted: January 02, 2012 at 4:37 PM / IP Logged
Very nice!!!!!   Thank You
yarisyeti
Posted: January 17, 2012 at 11:21 PM / IP Logged
Does the yaris need a transponder based immobilizer?
Posted: January 20, 2012 at 3:04 AM / IP Logged
This particular vehicle did not have a transponder based immobilizer system.  As shown on the Ignition Switch picture ( 5th photo down from top ) no antenna ring was in place in the groove at the end of the key cylinder.  This was a very base model.  All bypass manufacturers do list modules for this vehicle, so they are out there.
sansag13
Member - Posts: 11
Posted: May 07, 2012 at 3:24 PM / IP Logged
Hi,
Can you please let me know which is "Horn" wire? I am trying to hook up horn wire of remote starter (with remote lock/unlock) with yaris but have a hard time to find horn wire.
Thanks,
:d
Posted: May 08, 2012 at 11:59 AM / IP Logged
Sorry, I didn't get a photo of that wire.  Customer didn't want horn
confirmation.  Here is the location from several wire guides  :
Bulldog Security :
 HORN      BLACK (-)           @ HORN SWITCH or DASH FUSE BOX, (WHITE, 32-Pin Plug(E) Pin 18
Ready Remote :
Horn Trigger     black (-)    horn switch or dash fuse box, white 32 pin plug (4E), pin 18
Audiovox :
 Horn    LIGHT GREEN  (-)      AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
 ALSO BLACK IN STEERING COLUMN HARNESS
Omega :
OEM Horn  BLACK (-)  HORN SWITCH
Should be pretty easy to locate.  Set Digital Multi Meter to 20V DC, connect Red
lead to +12V constant and Black lead to suspect wire.  When horn button is pressed,
the DMM should read +12V.  The steering column should be easy to access and
find this wire.  ( It won't be in the Headlight Connector pictured above and  stay
away from any Yellow connectors or Yellow harnesses - air bag.)
Posted: May 09, 2012 at 5:47 PM / IP Logged
I'm actually surprised at no immobiliser. The Yaris comes from the UK and as I've said before, they all have immobilisers for Europe.
Funny I've never seen one in the UK without power windows and locks.
sansag13
Member - Posts: 11
Posted: May 22, 2012 at 8:33 AM / IP Logged
Thank you Kreg.. Horn connection worked out as per your information.. Thank you everybody for helping this novice..
:d
rhendy87
Member - Posts: 7
Posted: October 18, 2012 at 4:43 AM / IP Logged
Hi guys,
i need a little help over here.
Can you please inform me where is the wire for
1.Oil Circuit detection
2.Cut oil and electric circuit off.
i am currently trying to install a remote start.I cant seems to find these 2 wire.
Any help is greately appreciated.
regards,
Rhendy
Page of 4
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
