2008-2011 Dodge Caravan Remote Start Pictorial
tccustoms
Posted: October 05, 2015 at 10:36 PM / IP Logged Link to Post Post Reply Quote tccustoms
That was the ticket....MUX it is, lol. Thanks alot!
ccomm911
Posted: November 13, 2017 at 5:52 PM / IP Logged Link to Post Post Reply Quote ccomm911
I have a 2008 Dodge GCV, the Cargo Version. I am adding extra interior LED dome lights. The existing interior dome lights slowly fade out after the doors are closed. This has already burned out one (cheap/China) LED dome light, because the slow voltage drop caused the LED dome light to flicker very fast. Does anyone know of a work around for this? I tried a relay, and same thing, the relay contact flutters, essentially the same result as when the LED is wired directly to the existing dome lights. Thanks in advance for any suggestions.
geepherder
Platinum - Posts: 3,668
Posted: November 13, 2017 at 9:09 PM / IP Logged Link to Post Post Reply Quote geepherder
You could try a BJT (transistor) in place of the relay.
ccomm911
Posted: November 14, 2017 at 7:30 AM / IP Logged Link to Post Post Reply Quote ccomm911
What size/value? And what would the connections look like?
geepherder
Posted: November 14, 2017 at 8:14 AM / IP Logged Link to Post Post Reply Quote geepherder
Value shouldn't be a huge concern, since it won't need to dissipate much power. If your trigger is positive, use an NPN. For a negative trigger, use a PNP. It doesn't need to be a Darlington, but you'll want something with relatively high hFE (gain). An hFE of 200 or more would be plenty. Couple that with an appropriate resistor, and you'll be in business.
Here's a link to a good website:
http://www.talkingelectronics.com/te_interactive_index.html
search "the transistor amplifier"
Once you understand the basics, you should be able to find something locally that'll work.
A basic circuit would be fused power to your LED's, from the LED's to the collector of an NPN. The base would be connected to your positive trigger through a resistor. (I usually cut the minimum gain in half, and do some math to find a resistor that'll work for me.) Connect the emitter to ground.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
