01 ford ranger viper 5902 remote start
Platinum - Posts: 7,802
Posted: August 06, 2012 at 7:20 PM / IP Logged
Seven flashes means Manual Mode Error.  Does the Viper enter into reservation mode properly?
For manual transmission mode to work, you need :
1. Viper must be programmed for Engine Checking = Tach Mode.
2. Tach Input wire must be connected to a valid Tach source.
3. Viper must be Tach Learned successfully.
4. Door pins must be connected and working.
5. EBrake (-) signal wired to Neutral Safety switch input.
6. Brake (+) must be connected & working.
After replacing the Viper brain, did you program for Tach mode and do a Tach
learn?
