a much needed delay
chunkyster
Posted: December 08, 2014 at 2:01 PM / IP Logged Link to Post Post Reply Quote chunkyster
Hi Guys I have an MP3 trike with an additional air horn which goes off when I press the bikes horn button.
I would like to introduce a small delay in my air horn (143db) setup.
I have included a jpeg to show my current setup. As you can see from the existing headlamp relay, I have taken a grey wire to a new relay. This wire goes live only when the engine is running. From a new fuse box I am powering the new air horn. What I would like to do is delay the air horn going off for an adjustable 0-1.5 seconds, in this way the on board horn goes off when I press the button for a friendly meep meep, but when I need a BLATT by holding the button for about a second before the air horn kicks in. If possible be also able to flash the main head lamp as well. The screaming banshee (139db) air horn has such a unit, but this is about £50 plus import duty, if you can get one without the horn it self. The air horn draws about 20 Amps and the main beam is about 5 Amps. the 2 new relays have 40 Amp contacts.
https://i1153.photobucket.com/albums/p513/chunky75blue/horn_zps8ea2fd34.jpg
Don't Steal the government don't like the competition.
tsquirtz
Posted: May 29, 2015 at 9:38 AM / IP Logged Link to Post Post Reply Quote tsquirtz
http://www./itm/DC-12V-H3Y-2-Power-On-Time-Relay-Delay-Timer-0-60-Second-DPDT-Base-Socket-NEW-/261320472183
chunkyster
Posted: May 29, 2015 at 1:17 PM / IP Logged Link to Post Post Reply Quote chunkyster
Hi tsquirtz, I gave up in the end and bought a Screaming Banshee control unit instead. look on y-tube for it.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
