02-04 Daimler Chrysler Car Stereo Wiring Harness Diagram
axel13
Posted: February 13, 2019 at 11:33 PM / IP Logged Link to Post Post Reply Quote axel13
looking for wiring harness diagram for 02-04 chrysler,jeep,dodge oem car stereo part# p56038588ak, thanks
motosaki
Member - Posts: 24
Posted: February 14, 2019 at 9:18 AM / IP Logged Link to Post Post Reply Quote motosaki
Radio 12V     gray/red     +     radio harness
Radio Ignition     blue/pink     +     radio harness
Radio Illumination     orange/tan     +     radio harness
Left Front Speaker (+/-)     green - green/brown     +,-     radio harness
Right Front Speaker (+/-)     gray - gray/brown     +,-     radio harness
Left Rear Speaker (+/-)     green/blue - green/orange     +,-     radio harness
Right Rear Speaker (+/-)     gray/blue - gray/orange     +,-     radio harness
this is for an 2003 dodge caravan hope it helps.
15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
Platinum - Posts: 13,674
Posted: February 14, 2019 at 10:55 AM / IP Logged Link to Post Post Reply Quote i am an idiot
What are you trying to do?
axel13
Posted: February 14, 2019 at 12:33 PM / IP Logged Link to Post Post Reply Quote axel13
Thanks for the fast response, I just repaired this unit for a friend (had a stuck cassette in it and needed a switch replaced) and want to bench test it and need to know where the power connection goes.
Posted: February 14, 2019 at 2:32 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Post a picture of the back of the radio so we can see which harness it uses.
axel13
Posted: February 14, 2019 at 2:57 PM / IP Logged Link to Post Post Reply Quote axel13
here is a pic of the connection on the back of the unit 02-04 Daimler Chrysler Car Stereo Wiring Harness Diagram -- posted image.
Posted: February 14, 2019 at 7:50 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Yellow line goes through the 2 terminals for constant power.
Red line ends at switched power.
Black line goes through both of the ground terminals.
Some of these radios are turned on and off via data. You may have to plug it back into the vehicle to test it.
Posted: February 14, 2019 at 7:52 PM / IP Logged Link to Post Post Reply Quote i am an idiot
http://www.metraonline.com/part/71-6502
This is how I came up with the above info.
axel13
Posted: February 14, 2019 at 10:12 PM / IP Logged Link to Post Post Reply Quote axel13
Thank you so much and you're right I will probably have to put it back in again, and again I really appreciate your fast response on this. have a good one!
axel13
Posted: February 17, 2019 at 12:33 AM / IP Logged Link to Post Post Reply Quote axel13
Update: Unit installed back in vehicle and working fine again,thanks for the info. Now I have a jvc kd-r720 that won't eject the cd, should be a easy fix though. Just started working on car stereos,I usually repair and restore vintage audio equipment so this is a nice break from that.
daronsvintageaudio.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
