1979 Volkswagen Bus, Keyless Entry, Power Windows
jamescourt
Member - Posts: 8
Posted: April 20, 2020 at 12:06 PM / IP Logged Link to Post Post Reply Quote jamescourt
Right, I think I have sussed out the wiring for adding an additional switch in the drivers door
so I can operate the passenger window from the drivers side.
Please can someone take a look and confirm it is correct?
1979 Volkswagen Bus, Keyless Entry, Power Windows - Page 2 - Last Post -- posted image.
That just leaves my other question that I would like the ability to unlock/lock all doors when I manually pull up/down the drivers side door lock. I thought by installing a 5 wire actuator in the drivers side door would achieve this, but i don't know how?
jamescourt
Member - Posts: 8
Posted: April 25, 2020 at 6:08 AM / IP Logged Link to Post Post Reply Quote jamescourt
OK, the above wiring for the power window switches is correct and works well.
Only thing I need help with now is how to wire up the actuators to the VIPER 211HV
I'd like to be able to Lock all doors from the master (I have a five wire actuator in the drivers door) door by using the key or when driving push down the door lock (as well as locking all doors remotely from the 211HV fob).
Please can someone help with this as I am now really stuck!
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
