Sub Wiring, 3 On Top, 1 On Front
sethwilliams88
Member - Posts: 23
Posted: September 12, 2019 at 11:39 AM / IP Logged Link to Post Post Reply Quote sethwilliams88
So if I have a box with 3-15s mounted inverted on the top of the box and 115 mounted regular in the front with the port all are dual 1 ohm subs running onto Crescendo audio 4.5ks strapped together at one on each how would I wire the subs so they don't fight against each other
Seth
Platinum - Posts: 13,674
Posted: September 12, 2019 at 7:10 PM / IP Logged Link to Post Post Reply Quote i am an idiot
On the inverted 3 connect the positive wire to the negative terminal of the speaker and the negative wire to the positive terminal, then treat the wires just as you would if they were not inverted.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
