Power Windows, 2005 Chevrolet Cavalier
the12volt
Administrator - Posts: 3,955
Posted: June 12, 2020 at 11:36 AM / IP Logged Link to Post Post Reply Quote the12volt
Assuming there are no mechanical issues with the rear windows and you used the correct gauge wire, the speed of the rear windows is probably normal.
You could use a relay energized by an ignition or accessory source with another 20 amp self resetting circuit breaker going directly to the battery instead of the factory location in the fuse box, but I would test it first before running any wire inside the vehicle.
You could also use heavier gauge wire throughout if you are currently using wire that is too small to use from the start such as 18 gauge or smaller. What size wire are you using?
Yes, you could add two relays per window motor with heavy gauge wire for 12V+ and ground, but again I would test one window for any improvement before running a single wire inside the vehicle.
And finally, before I did anything, unless they are painfully slow, I would leave well enough alone ;).
Power Windows, 2005 Chevrolet Cavalier - Page 2 - Last Post -- posted image. the12volt • Support the12volt.com
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
