4 Wire Switch Swap
savagetusk
Member - Posts: 6
Posted: July 16, 2020 at 12:38 AM / IP Logged Link to Post Post Reply Quote savagetusk
I am trying to figure out a way to swap a 4 wire plug to another 4 wire plug and the same with another at the same time. Kind of a flip flop. See the diagram and let me know if the is possible. Thanks! 4 Wire Switch Swap - Last Post -- posted image.
eguru
Copper - Posts: 340
Posted: July 16, 2020 at 6:53 AM / IP Logged Link to Post Post Reply Quote eguru
More details please. By "swap" do you mean "connect"?
Perhaps pictures of the connectors would help.
savagetusk
Member - Posts: 6
Posted: July 16, 2020 at 11:59 AM / IP Logged Link to Post Post Reply Quote savagetusk
I'll try to get some pictures tonight. This is for the electric throttle on a jetski and the IBR. My wife likes them swapped because she broke her wrist but I prefer the standard setup. I can physically swap the plug connections but I'm trying to see if there is a way to swap the 2 connections with a switch of some sort. This would not be on the fly and be stored inside the hull so the engine would be off when switching. From the engine there is a 4 wire plug that goes to the throttle and one that goes to the IBR..if that helps explain my drawing.
eguru
Copper - Posts: 340
Posted: July 17, 2020 at 8:23 PM / IP Logged Link to Post Post Reply Quote eguru
So you basically need to swap 8 wires (or less if there are common grounds or 12V going to the 2 controls).
an 8 pole double throw switches could do the job. Does it need tp be water resistant?
Something like this (but possibly needing to be water resistant)
https://www./itm/HONEYWELL-22AT2-T-Toggle-Switches-Toggle-SW-8PDT-2POS-NEW-IN-BOX-/283480478553
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
