Running 3 Ohm 6.5s In Parallel With 4 Ohm Tweeters
kenwood_nut
Stock Boy - Posts: 227
Stock Boy spacespace
Posted: April 01, 2021 at 11:32 AM / IP Logged Link to Post Post Reply Quote kenwood_nut
I'm getting ready to do some rocket science calculating, so I need help! I just bougth 4 new JBL GTO full-range speakers, the GTO930 6x9's for the back and the GTO629 6.5's for the front doors. The 6x9's are 2.5 ohms and the 6.5's are 3 ohms. Nice! Anyway, I'm also going to keep my present setup of running my tweeters in parallel off the front channel of my Eclipse 4-channel amp. My present Nakamichi 4-channel amp is doing okay, but not good enough. I'm running the 4 ohm Cerwin-Vega tweeters in parallel with the front Pioneer 4 ohm door speakers. So my amp should be running the fronts at 2 ohms if I'm not mistaken. Sounds 10 times better than the rears at 4 ohms, that's for sure! But now I'm worried because I'm trying to figure out how I'm going to run 3 ohm speakers and brand new Cadence 4 ohm tweeters off an amp that's only 2 ohm stable. Apparently I can't run them in parallel. If half of 4 ohms is 2 ohms, and half of 3 ohms is 1-1/5 ohms, it looks like I’ll be forced to run them in series. Is that correct? Or maybe series-parallel? The last thing I want to do is run the tweeters off the head unit, always a waste of time and not a good idea anyway. So would I add 4 to 3 and come up with 7 ohms, which would be 3-1/2 ohms in parallel to each channel? If that’s right, it seems I would be fine. But I’m guessing it can’t be that easy. I’ve never owned 3 ohm full range speakers before so this equation is new to me. Can anyone offer and ideas here? I do NOT want to fry my new Eclipse amp, so series connection would work if I have no other choice! One final note unrelated to my front stage dilemma… I’ve decided to run the rear 6x9’s in mono instead of stereo. Makes for a better rear fill than stereo. This will be the most I’ve EVER spent on speakers in my life, and it’s only thanks to that stimulus check! Hey, if I’m going to stimulate the economy, it might as well be the car audio economy! LOL!
The way I figure it:
4 ohms plus 3 ohms is 7 ohms. Running THIS in parallel would be 3.5 ohms. Is that right? But don't they say your amp actually SEES half of that? So my amp would SEE it as 1.75 ohms? Dang this is complicated. Apparently JBL speakers weren't designed to be run in parallel. They boast their ability to sound good even if driven of a head unit with no amp, which is believable. But I sure can't/won't run my tweeters off the deck.
So my only real question that I had to make more complicated than it really needed to be is this:
Am I safe running a pair of 4 ohm and a pair of 3 ohm speakers in parallel off an amp that's only 2 ohm stable?
I'm guess not. I'd have to run them in series, right?
About the only thing I know FOR SURE is that this is the most I've spent on full range speakers in my life! $90 for the 6.5's and $172 for the 6x9's, plus tax!
the12volt
Administrator - Posts: 3,955
Posted: April 01, 2021 at 12:16 PM / IP Logged Link to Post Post Reply Quote the12volt
Wiring one 3 ohm speaker and one 4 ohm speaker in parallel would have a nominal impedance of 1.71429 ohms, however impedance is relative to frequency. If you are using 2-way passive crossovers between the 6.5" speakers and your tweeters, then the lowest nominal impedance would be 3 ohms below the crossover frequency and 4 ohms above it*. If you are only using passive crossovers on your tweeters and not on the 6.5" speakers, then everything above the crossover frequency will have a nominal impedance of 1.71429 ohms and everything below the crossover frequency would have a nominal impedance of 3 ohms*.
*Not counting any changes in impedance per speaker at different frequencies. Example: If my memory serves correctly, Rockford Fosgate 5" and/or 6" midrange drivers back in the '80s had a natural rolloff at and above 5KHz and did not require low pass filters unless you wanted to limit frequencies below 5KHz. At 5KHz and above the speaker's impedance rose sharply and greatly.
https://www.the12volt.com/caraudio/boxcalcs.asp#par
https://www.the12volt.com/caraudio/passive-crossovers.asp
Running 3 Ohm 6.5s In Parallel With 4 Ohm Tweeters - Last Post -- posted image. the12volt • Support the12volt.com
kenwood_nut
Posted: April 01, 2021 at 10:54 PM / IP Logged Link to Post Post Reply Quote kenwood_nut
I removed my defective Cerwin-Vega active crossovers and now run 5.5k bass blockers plus 20-watt 8-ohm resistors. Does this help? The Cadence tweeters I just ordered only have passive crossovers.
mpranger
Posted: June 13, 2023 at 11:58 PM / IP Logged Link to Post Post Reply Quote mpranger
Hey, I have the same thing going on with Infinity speakers. I've ran both Infinity reference 6.5 and 6x8 3 ohm speakers with a set of Infinity reference 4 ohm tweeters for years. Never had a problem. Have them with a set of 2.5 ohm Infinity kappa 6x8 right now, running off a 100watt X 2 Alpine amplifier. I've been running that setup since about the same time you posted this in April 2021. If anyone else needs to know, the administrator that commented on this thread is right. The impedance won't be too far off.
Mp
mpranger
Posted: June 26, 2023 at 12:00 AM / IP Logged Link to Post Post Reply Quote mpranger
Edit. Have been running the Kappa plus tweeter setup since 2021. Have been running those same 4 ohm Infinity reference tweeters with either Infinity 3 ohm 6.5 or 6x8 since 2007. Never had a problem.
Mp
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
