3 Position Toggle Switch On-On-On
bgloyalty2
Posted: April 16, 2021 at 9:56 PM / IP Logged Link to Post Post Reply Quote bgloyalty2
I'm trying to find a 3 position toggle switch that is on-on(both)-on. 12v, at least 5A
I have lights on the front and rear of my truck. I have a main power switch, but then want to put in a 3 position "selector" switch. So I could choose rear-both-front. I can't seem to find a switch like that and I'm sure I just have no idea what it would be called.
Any help would be appreciated.
Platinum - Posts: 13,671
Posted: April 18, 2021 at 6:57 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If this will help you I can provide help with the wiring. It is a 4 position switch. You can eliminate your on off switch if you want. Position 0 can be off. Position 1 can be front, rear, or both. Position 2 can be front, rear, or both. Position 3 can be front, rear, or both.
https://www.amazon.com/Baomain-Changeover-LW28-20-Terminals-Positions/dp/B014KPR3D2/ref=asc_df_B014KPR3D2/?tag=hyprod-20&linkCode=df0&hvadid=198072808542&hvpos=&hvnetw=g&hvrand=11474119651952443693&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9025344&hvtargid=pla-323303023372&psc=1
If you are going to do this and order the switch, get this as well. You will only need 2, this is for a pack of 20, so only order 1.
https://www.amazon.com/MCIGICM-Rectifier-Electronic-Silicon-Diodes/dp/B07Q7YNZZF/ref=pd_sbs_1?pd_rd_w=65KIW&pf_rd_p=2419a049-62bf-452e-b0d0-ca5b7e35a7b4&pf_rd_r=2FZ5PPFC4VEJXF1M3R9J&pd_rd_r=e539079b-1390-490c-ab47-1cee2c5f136a&pd_rd_wg=CH2FJ&pd_rd_i=B07Q7YNZZF&psc=1
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
