2000 Chevrolet Blazer, Audio Dream To DSL Nightmare
alphapet monkey
Posted: April 09, 2023 at 10:41 PM / IP Logged Link to Post Post Reply Quote alphapet monkey
Lets start by saying I've been in a wth moment for about 3 weeks now.I've twisted enough wire in my time to consider myself more than a novice but humble enough to know I'm not an expert,To add depth to my tail I was held against my will by the N.D.O.C for the last decade so theres been a crash course in retraining to satisfy my car audio third eye.I've installed 3 systems in as many automobiles in the last 1.5 years that i was released.Lets get to the point.
       Kenwood head unit,\Kenwood 6.5 mids for rear doors Rockford Fosgate 4.5for were the tweets go in a 2000 chevy blazer sl.Hyanka 6.5 components jn the fronts.On to the Audio control DQDX.Pioneer gm-d9705 2000 watt 5 channel for mids and highs.pioneer gm-d9701 mono for 2 Hyanka 10 in.subs.Ok i installed everything had a litle engine wwhine figure ground issue,i separated all the grounds check with multi meter all is cool, i got 13 across the board whine is worse. go back to original set-up,try the j9 switch in audio control, switch from unbalanced to balanced nothing.Now the whine was bearable but just wizzed me off.so im setting eating my lunch at break listening to Tarzan by prof and wanngg wonng wwaa wwaa loud as all hell my gm9705 shoots into protect mode with a puff of smoke.Send that to pioneer hopefully they cover it.i decide to rewire my hole get down and do it big,and i mean everything biggest guage wire extra distrabution blocks nothing spliced no female to female rca usage no spliced speaker wires tuked under the carpet,everything perfect.i got a 1500 watt bluapunkt pof that survived 3 different vehicles,it saya 1500 but its more like 32 watts.I through it in until i could grt the gm9705 back it worked,for about 20 minutes then wwong wang wang to protect mode.So i bypass the dqdx thinking its faulty and and the bluapunkt is down one channel,so i check back to audio contrl to see what channel is messed up and it woerky again,well doodie lets check the blaupunkt and all 4 channels work again.so im puzzled but hey might aswell run with its safe to take my daughter to the store right maybe even have her listen to the difference between no dqdx and with dqdx. So we pull out bypassing dqdx when i hook back up to thedqdx hella whine, so i unplug go back to bypas theres a slihght whine so thats were i am ,one more thing i haven a 3500 watt capacitor ewith its own ground hooked up to the mono what is going on am i pulling to much off the electricl do i need a bigger alternator another battery?should i just catch it all on fire?:
X
keith barney
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
