2019 Nissan Versa S, Panasonic To Bosch Radio Swap
austinversa2
Posted: September 23, 2023 at 6:09 PM / IP Logged Link to Post Post Reply Quote austinversa2
Hello,
I was looking to swap factory radios on a 2019 Nissan Versa S. These cars came with one of two factory units that look nearly identical. One is a Panasonic unit and does not have Carplay/Android Audio and the other is a Bosch unit that does have carplay/android auto. I am attempting to upgrade the lower end Panasonic unit for a higher end Bosch unit to get Carplay/Android auto. They use the same connectors but the wires going to those connectors are not identical. To further complicate matters it appears that on the 2019 Nissan Versa this was the only year that these radios/connectors were used so information seems to be inaccurate or hard to find. This was a 2019 only configuration. It would be very helpful if I could get a diagram of the pins to both of the connectors to help rewire the radio. The radio itself is nearly a plug and play except the backup camera and steering wheel controls did not work when plugged in so will need to rewire those. Any help yall can offer would be appreciated!
Thanks in advance.
Here are the two connectors I need diagrams for:
2019 Nissan Versa S, Panasonic To Bosch Radio Swap - Last Post -- posted image.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
