2 Switches, One Load Via Relay
marc115uk
Posted: November 07, 2023 at 6:08 PM / IP Logged Link to Post Post Reply Quote marc115uk
I want to control an air pump with 2 momentary switches. Planning to hook air pump up to relay. Pump will be either on or off when switch held/let go of. Wondering if the following wiring would work. Battery to pin 30, pump to 87, 85 to ground, then both switches connected to pin 86?
Or is there a better/safer way?
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
