2003 Chevrolet Tahoe, Aftermarket Stereo, Accessory Wire
sabean
Member - Posts: 14
Posted: February 28, 2024 at 3:13 PM / IP Logged Link to Post Post Reply Quote sabean
Can only get aftermarket head unit to come on with a jumper from the yellow (power wire ) to the red (accessory) wire
Paul hoffman
Platinum - Posts: 13,671
Posted: February 28, 2024 at 8:38 PM / IP Logged Link to Post Post Reply Quote i am an idiot
You have a couple choices. Return the harness and get the proper one. Metra AXDICL2 will provide a retained accessory output. This will keep the radio on until you open the drivers door, just as your factory radio did. Or, if your AC control has 2 separate plugs on it and one harness has larger wires than the other, you can tap into the brown wire of the harness with the larger diameter wires. Or use the bundle of red wire and the fuse tap that came with the harness you have and run it to and tap into the Windshield Wiper fuse in the fusebox at the end of the dash on the drivers side. It is labeled WSW on the diagram inside the cover on end of dash.
Ween
Platinum - Posts: 1,366
Posted: February 29, 2024 at 6:07 PM / IP Logged Link to Post Post Reply Quote Ween
https://www.gmupfitter.com/wp-content/uploads/2021/05/2005_LD_CKFullSizeElectrical.pdf   pages 49 and 52 although one might peek around.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
